What size is the intake tube fitting?
Old Aug 13, 2007 | 09:20 PM
JonW's Avatar
What size is this fitting on the intake tube?
Old Aug 13, 2007 | 09:43 PM
m05fastbackGT's Avatar
If you're referring to the stock intake tube size Jon ? it's 80mm in diameter..As for the fitting itself ? I'm not really sure, but I thought it was also the same size
Old Aug 13, 2007 | 09:46 PM
JonW's Avatar
I'm talking about the fitting that points downward in the picture. There is a hose that slips onto it.
Old Aug 13, 2007 | 10:11 PM
bluethunderhorse's Avatar
1/4 or 5/16
Old Aug 13, 2007 | 10:18 PM
oh ok..you mean the plastic reducer tube right ? yea there's a hose that attaches to it, and the other end goes into the crankcase..Anyway I agree with Steven on the 1/4 or 5/16 size..
Old Aug 13, 2007 | 11:23 PM
JonW's Avatar
Would 8mm be close enough?
Old Aug 14, 2007 | 03:13 AM
8mm is the same size as 5/16
Old Aug 14, 2007 | 09:45 AM
Tucker's Avatar
It's 3/8", but it's a custom fitting made for Ford.
3/8 hose will fit on the end of it.
Jay
Old Aug 14, 2007 | 10:18 AM
JonW's Avatar
So what are the aftermarket CAIs using for that fitting? Can I take the OEM fitting out and put it in an aftermarket inlet tube?
Old Aug 14, 2007 | 10:25 PM
Most aftermarket CAI's have their own fittings already molded into their inlet tubes..The Steeda inlet tube on the other hand ? does require re-using the stock fitting..However ! it's a royal pain in the a$$ when it comes to removing the stock reducer fitting, from the OEM inlet tube..
