What is this?
Old 1/22/06, 02:22 PM
mco05gt's Avatar
What's really interesting is that I had a fairly extensive groan at a specific speed/rpm range (70-73mph @ 2300 rpms in any gear). Since I found it easy to avoid that range, I did nothing about it, as I considered it to be a minor issue that I could live with, and wasn't too thrilled at the prospect of numerous trips to the dealer as it's one of those problems that can be very hard to diagnose and pin down.
What ended up happening is that sometime after about 10,000 miles, it went away all by itself
So in the end, doing nothing worked in my favor!
I wish you had found out what that was because my car does the exact same thing. I am also not crazy about taking my car in for service,who knows how long they will need it or if they can even hear or feel it.
Old 1/22/06, 02:40 PM
cop on my back's Avatar
Well if mine has those weights, it won't be for long.
Old 1/22/06, 05:37 PM
GottaHaveIt's Avatar
Hi Richard I welded them on at the dealer last Tueday morning for you ! I came in right after you .
Old 1/22/06, 05:54 PM
NJ3
NJ3's Avatar
Mine doesn't have them, maybe just you Automatic Transmission guys get them.
Old 1/22/06, 06:08 PM
SRQ05GT's Avatar
Originally posted by 05stangkc@January 22, 2006, 4:20 PM
[attachmentid=43440]
This is an Early TSB Used on Few Cars. It is my belief that the New Tsb on the rear axle gears is the True Fix.
[attachmentid=43441]
Man I love my new Cable Internet at the House! I can pull up fords site and Rip this info out! Used to be able to drive to detroit in the time it took to download stuff!
Welcome to the new world..... (Hunt for Red October).
Old 1/22/06, 06:40 PM
spyder7724's Avatar
my theory is the noise comes from the posi unit. ford had those issues with the explorer also. they use the same posi unit as the new mustangs(31spline). while rotating my ring gear i found the backlash varies by as much as .006! in other words the ring gear is off center slightly. definitely enough to cause harmonics and vibration. oh and my 06 auto has them too. wonder why some do and some don't. i was told it was a mid year change for '05...guess not.
Old 1/22/06, 06:49 PM
SRQ05GT's Avatar
Should I take mine off?
Old 1/22/06, 07:16 PM
thump_rrr's Avatar
Mine was built April 5 2005 and doesn't have them.
Old 1/22/06, 07:25 PM
SRQ05GT's Avatar
THATs IT. MINE ARE COMMING OFF! (anyway i can always put them back on).
Old 1/22/06, 07:32 PM
biznazion's Avatar
I'm a 4/2/05 build and I don't have them either.
Old 1/22/06, 07:50 PM
spyder7724's Avatar
since mine makes noise at 40-60mph anyway i'm also taking them off. 10lbs less i have to lose to reach my goal.
Old 1/22/06, 08:24 PM
GOFISCH's Avatar
My car has them. Feb 2005 build date.
Old 1/22/06, 08:25 PM
ren274u's Avatar
darn my 06 has one on each side, i gotta remove those tommorow
Old 1/22/06, 08:39 PM
hawgman's Avatar
Mine is 01/05 and doesn't have them
Old 1/22/06, 08:44 PM
silverGTvert's Avatar
Originally posted by GottaHaveIt@January 22, 2006, 6:40 PM
Hi Richard I welded them on at the dealer last Tueday mornibg for you !
Old 1/22/06, 09:11 PM
I talk to cones.
softbatch's Avatar
Mine was built in June 05 and doesn't have them.
5 speed GT
Old 1/23/06, 05:23 AM
DallasStang's Avatar
It sounds to me like NJ3 is right. Are only the Auto guys finding these behemoth contraptions under their cars. My stick '05 doesn't have them either. :scratch:
Old 1/23/06, 06:43 AM
Laga's Avatar
Mine is a Gt auto, build date 3-10-05 and does not have them
Old 1/23/06, 08:07 AM
wsmatau's Avatar
I don't have them (FEB '5 build w/manual tranny) but I have had a ridiculous shutter/vibration sometimes when I really accellerate hard. At first i thought it had something to do with the TCS, but I've had the same problem with it off also. Any input?
Old 1/23/06, 11:43 AM
  #40
eighty6gt's Avatar
Frank, is it at low speeds? It's probably wheelhop.
