V6 engine swap to 5.4 Nav and now to a GT500
Old Jan 16, 2013 | 09:13 PM
5.4 DOHC's Avatar
I bought a take-out 08 GT500 engine complete with only 9K miles on it. I plan on removing the 5.4 Nav engine and dropping in the Shelby engine in my 2006 Stang. I need help deciding what fuel system to run with...E85? 93octane? boost a pump, M-9407-GT05, or Aeromotive A1000 Mustang Stealth pump. returnless? fuel pressure regulator with a vac/boost input? also I question if the GT500 crankshaft balance is the same as a 4.6 3V and 5.4Nav? I'm hoping the 03 cobra flywheel/clutch set-up from the 5.4 Nav engine will transfer to the GT500 engine without balance issues. Nav engine runs off a 3V ECM. I'll just swap the GT500 harness ECM pins around to match the 3V locations and re-tune. what do you think?
Old Jan 17, 2013 | 09:56 AM
muscledom's Avatar
Not to get your post off topic man but how difficult was it to swap in the 5.4? I'd assume there was more bs going from a 6 to an 8. Time? Any fab? Cost? Thanks man
Old Jan 17, 2013 | 05:55 PM
5.4 DOHC's Avatar
All OEM parts except upper intake. I got the 5.4 Navigator engine free. It had seized camshaft. Bought both reman heads for 400.00 off ebay. Bought 3v brackets and drive belt accessories from craigslist. 3v oil pan. Nav engine has 8 bolt flywheel so I used flywheel from cobra. 3v ECM/tuned of course and harness minus the cam sensors. Shelby GT500 long tube headers. Sold v6 and trans for 3k. See YouTube videos "Scott 5.4 DOHC". But like everything, gets boring and you go looking for the next performance mods.
Old Jan 17, 2013 | 06:23 PM
Knight's Avatar
Needs to be more Astony
Cool swaps! Did you ever have the NAV 5.4 dynod? Curious to know what it was putting out.
Old Jan 17, 2013 | 08:46 PM
muscledom's Avatar
Dude that's a really cool swap. Especially since it came from the bane of the mustang world, the dreaded v6 auto lol. Once she's paid off I'm gonna do a GT500 motor n tranny swap. What kind of numbers did yours put down?
Old Jan 18, 2013 | 04:40 AM
JerryG2163's Avatar
Thing sounds great in your videos. Power numbers?
Old Jan 20, 2013 | 06:58 PM
5.4 DOHC's Avatar
anyone running E85? what fuel pump to use? fuel lines? do I double the injector size?
Old Jan 24, 2013 | 04:09 PM
5.4 DOHC's Avatar
after research, available fuel pumps are the M-9407-GT05 $700(twin pumps, OEM GT500, returnless), Aeromotive 18676 $450 (single pump, must run a return fuel system $700), Fore Innovations $650 (twin pumps, returnless, need to run two FPCMs $500). all can run 93 or E85. GT500 pump can support 700hp, but needs to run the FPCMs and therefor has a delay/decrease between shifts (duty cycle drops from 80% to 50% then back to 80%, fuel drops just a little and you feel a bog/sag when your back on the accel). very easy install, only else I would need the fuel line from rail to shock tower. stay wih the 49lb injectors. should be ok. But if I go with the Aero or Fore pumps, use E85, I would need 80lb Cobra Jet injectors $400. what to do??
Old Jan 30, 2013 | 07:52 AM
Knight's Avatar
49lbs injectors seem too small. 03 cobra guys run 60's with 93 oct or 80's with E85, for that power level. Also most run Dual Ford GT pumps, which might be what the new GT500 runs too. Don't remember.
Edit: just realized you are talking stock GT500 engine not a 700hp one in regards to injectors, stock power with E85 would be 60lb/hr, but might as well buy 80's for future power upgrades
Jul 8, 2016 08:53 AM
earl610
Sep 6, 2015 05:48 PM
Cdvision
Sep 5, 2015 05:22 PM
JTB
Motorsports
Sep 3, 2015 10:50 AM
