upper control arms install
Old Dec 26, 2008 | 03:25 PM
mike2005GT's Avatar
can anyone add some pictures to this thread about what the upper control arms look like when installed ?
Old Dec 26, 2008 | 04:26 PM
classix_stang289's Avatar
control arm "singular" our cars have only one unlike the Sn95 models. i have not seen any install pics of this products but i can point you in the right direction. Call steeda and ask them to supply you with some pictures. they have a nice adjustable upper control arm and they will definitely be able to answer any suspension question you might have. they are great and i have done business with then many times.
Old Dec 28, 2008 | 12:13 AM
jamesdem1123's Avatar
I have a clunking sound coming from the back (believe it's just a loose sway bar) so I'm going to work on the suspension tomorow. Maybe I'll try putting my UCA on. If I do i will take pics.
Old Dec 28, 2008 | 08:48 AM
cool, is it a adjustable peice? what brand? i need to get one but not sure which to get.
Old Dec 28, 2008 | 11:02 AM
tom281's Avatar
I installed an adjustable Steeda unit a few months ago, but didn't take any pix.
Have fun..... especially adjusting it while on the car.
Old Dec 28, 2008 | 01:48 PM
Mine is a CHE non adjustable unit. I didn't have time to put it on today. I did take pics of the stock one in place. For the most part its two bolts, but will probably have to take out the over the axle pipe to get to the bolt that connects to the body.
Old Dec 28, 2008 | 01:57 PM
06SatinSilver's Avatar
they can be a pain depending on which brand you get...if its a adjustable one make sure you measure and set it to the stock length when you get the stock one out...no adjustment may be needed and if not then no messing with big jamnuts in a tight spot...the install i did with a spohn perf. spherical i had to unbolt the mount plate (3 bolts , one under back seat, very tight factory torques) because the top bolt for the arm was long and i needed more wiggle/play in the area to get it in...not all may have that issue...just be aware that it can be there...i have also heard of people needing to drop the tanks to get the entire mount plate out as well...don't know why that would be needed...just telling you what i read...good luck..its a good mod that add some lateral stiffness i believe...
Old Dec 28, 2008 | 04:26 PM
would it be better for you to remove the muffers to get a little more play on the over axle pipes without taking them out? or do you see yourself better off taking the pipes out?
im just wondering for when it comes time for me to get under there and do mine
Old Dec 28, 2008 | 07:27 PM
You can try, but I dont think you will have enouh room. I have the pypes midmuffler system and the control arm is about 6 inches from the over the axle pipe, not enough room for an impact wrench.
Old Dec 28, 2008 | 07:29 PM
there is no reason to remove any exh parts whatsoever!!! they do not affect the install
Old Dec 28, 2008 | 09:15 PM
RRRoamer's Avatar
I just loosened the three upper control arm mounting bolts to allow the mounting bracket to drop down enough to allow the bolt to be pulled out. It was fairly easy to do actually.
Mackitude
Aug 17, 2015 04:14 PM
SMBJoshy
Aug 16, 2015 02:48 PM
09-gt/cs
05-09 Exterior Modifications
Aug 2, 2015 10:08 AM
killaz05
Jul 24, 2015 08:49 AM
