Upgrade to HID??
Old Apr 20, 2007 | 10:16 AM
goldenpony's Avatar
Upgrade to HID??
I am looking for those that have installed the Bi-Xenon, dual beam HID kit from Stangmods. Are you happy with them? Would you do it again? I am seriously considering the 6000K kit. Help a brother out.
Old Apr 20, 2007 | 11:28 AM
eci's Avatar
eci
I'd wait for the 2008 factory option. It will be available for seperate purchase.
Old Apr 20, 2007 | 11:47 AM
kevinb120's Avatar
yup.
Old Apr 20, 2007 | 03:41 PM
RobK's Avatar
I bought one. I'll be installing once I receive my car (hopefully next week!). I'll update then...
Old Apr 20, 2007 | 04:58 PM
official_style's Avatar
i bet its the same as the saleen headlights, since they are made by sylvania.
Old Apr 20, 2007 | 05:15 PM
mrkabc's Avatar
The Saleen HID kit isn't a bi-Xenon set - it uses a motorized reflector to simulate a "high" beam but doesn't really change the bulb intensity or light up another bulb.
Curious to see how the bi-Xenon setup looks and works, since turning on an HID light requires a brief "warmup" period before full intensity.
Old Apr 20, 2007 | 05:19 PM
05stangkc's Avatar
As Far as the FORD Hid Setups as Soon as Ford Releases them and The 08 Wiring Diagrams I will Certainly Investigate their Retrofitability.
KC
Old Apr 20, 2007 | 05:56 PM
jayguy's Avatar
"Retrofitability"
If that's not a real word, it should be.
Old Apr 20, 2007 | 07:39 PM
goldenpony's Avatar
HID's
Sounds good. HID's is the one mod I really want-but not enough to spend $900 for Saleens. That's just wrong.
Old Apr 20, 2007 | 08:11 PM
RobK's Avatar
I've only ever seen bi-xenons that move the reflector. I've never seen multiple bulbs or varying intensity...
Old Apr 20, 2007 | 09:01 PM
Dougxox's Avatar
got a quote from my dealer on the 08 HID's to be modded to my car....$750 each with out bulbs and ballasts. they did not have pricing on those yet, but guessed about $4000 to $4500 installed...YIKES.
Old Apr 20, 2007 | 09:10 PM
errrbody should listen to me, they are gonna be the saleen headlights.
mrtraffic's Avatar
Smile Hid
Have had them installed for a couple months, work great. the instructions seem to be for some other car tho. just had to figure the three wires the tell which is high-lo beams, overall rating a 8 out of 10.
Old Apr 20, 2007 | 10:07 PM
mvon919's Avatar
They might be the same design, but Saleen light are not made by Sylvania... Saleen uses OEM HEad light housing with 3rd party HID/reflector assy. Comprende?
Old Apr 20, 2007 | 10:46 PM
RedDragon777's Avatar
well i know for a while they are going to be like the saleens were and will be around $1200 for a while then drop down to $800 or $700 within a year, this mod to me is more of a want then a need
Old Apr 21, 2007 | 06:22 AM
metroplex's Avatar
Osram is the R0X0Rs!1111!!!!!1oneoneone!!1! Hopefully they had the Germans design the HIDs for the 08 Mustangs.
I'm contemplating buying a wiring upgrade kit, or waiting for the HID retrofit.
Old Apr 21, 2007 | 07:53 AM
AFBLUE's Avatar
Dethroned Nascar Guru
Indulge me. What is so great about HID lights? I just read on another post how great the current ones are for illuminating on hi-beams.
In other words, why would folks pay so much for these lights, if the currents lights work fine?
Old Apr 21, 2007 | 07:56 AM
RobK's Avatar
You can't drive around with your highbeams on all the time!
Old Apr 21, 2007 | 08:03 AM
AFBLUE's Avatar
But are the low beams so bad that you need to speed $800-1200?
I'm not arguing, I'm just trying to understand why folks feel the need to spend this much money for replacement lights.
EDIT: Found this FAQ for HID lights. http://orca.st.usm.edu/~jmneal/tiburon/hids.htm
Old Apr 21, 2007 | 11:28 AM
metroplex's Avatar
My stock low beams are inferior to the low beams on my Crown Vic, which I think is inferior to the UNECE-compliant H4s on my T-bird. The HIDs used on foreign cars like Lexus, Audi, Mercedes-Benz, BMW, etc... are designed for high speed driving at night in Europe so they don't over-run their headlamps. With US/DOT/FMVSS compliant head lights, we're dealing with junk that barely throws light out far enough at 65 mph (in total darkness) to give us the necessary reaction time/distance.
HIDs put out a sh*tload more light than halogen light assemblies. It's the sheer amount of candelas being put out, plus with a sharp cut-off that makes it superior to normal halogens
I am not a fan of the cost, but if I had a choice between the best halogen bulb setup (the top choice at TMS: SilverStar H13s) and UNECE compliant HID projector headlamps, it would take less than 1 second for me to choose the HIDs; the obvious better choice.
