Tried to replace my battery today and failed :(
It's unlikely the average Mustang enthusiast will drive in them, but they won't function properly in arctic conditions without external heaters. Ford and other OEM's test their vehicles in various conditions and the Optimas would most likely fail in the cold weather testing and incur an additional and unnecessary cost to the vehicle.
I had the same problem as you, car wouldnt take a charge...and the green stuff on the positive terminal. Got my Gold series from Sears...works great. Barely fits though and the battery sleeve will no longer fit.
Location: New Carlisle, Ohio (20 miles north of Dayton)
I went thru this about a year ago. Looked at the Optima battery and they were expensive and didn't fit the battery tray very well plus the insulation blanket was very loose. Than I looked at a Sears Diehard Gold. I was a hair larger and the blanket would fit at all. Finally settled for a stocker from the dealer. Cost was $100 bucks and has a 36 month free replacement warranty before it starts being pro-rated. I would buy a stocker again.
Tim
We've looked extensively at Optimas in a lab. A lot of the marketing is just hype that gets passed around in car enthusiast sites. If the Optimas were the same price as the regular batteries, I wouldn't have a problem using one as long as you don't live way up north.
I guess it all depends...if people hype them up enough and people are willing to pay what they charge then it will continue that way until something gives... I don't think the Optima batteries necessarily perform better than other brands but I think many people, like myself, continue to use them because they have had good luck.
Until I have a really bad experience with them, I will still use them. But I don't think they are any better than any brand such as Interstate, Bosch, Die Hard, Duralast, etc etc....it all comes down to brand preference.
My stock battery on my 05 GT is dieing on me.
A few days ago it needed to be jumped and there's wierd stuff growing on the terminals.
Any how I went to my local Autozone and they looked up my car model/make and came up with this:
http://www.autozone.com/selectedZip,.../selectZip.htm
It's the Duralast brand battery.
Anyhow I proceeded to install the battery and to my suprise, it didn't fit![Mad](https://themustangsource.com/forums/images/smilies/mad.gif)
In the tray that holds the battery, there are these 2 plastic tab things that slide out. The Duralast battery is longer than the stock one so it was actually sitting on top of the tabs. No problems, the tabs slide out.
Next problem.
The posts on the battery are further apart than the stock battery and the cables would not span that distance.
Aghhhhh, I had to take it off and reinstall the stock battery.
What battery should I buy that will fit properly - OEM ?
Next problem.
Jed
![](http://i170.photobucket.com/albums/u266/StangSnap/Beams%20and%20Glass%202/IMG_8194.jpg)
I installed a Red Top Optima but I had to take a dremel tool and grind out the tab on the inside of the stock battery tray. I bought a billet battery holder from Wyland that I fasten to the stock tray. It was a little bit of work but I think it was worth it. I didn't have an issue with cable length, I did have to grind down a terminal screw just in case it may short to the bottom of the hood.
Jed
Jed
That doesn't look like the series 35 red top that Optima recommends for the 05+ Mustang. Check out tdbrowns post above and note the position of the terminals in his pic - all the way back similar to the stock battery. Could that be why you had to grind down a screw to get hood clearance? What series is your battery?
![Confused18](https://themustangsource.com/forums/images/smilies/confused18.gif)
Jed
I got my new battery installed after much aggravation.
Here's the story.
Autozone sold me a Duralast battery that they said would fit my car (as I mentioned earlier), however, it didn't fit.
So I asked for my money back.
They said they couldn't do that![Banghead](https://themustangsource.com/forums/images/smilies/banghead.gif)
They would only do an exchange.
I said to them that it was their fault for selling me a battery that didn't fit.
So I asked if they had any Optima batteries and they didn't have any that would fit in stock.
So I tried 2 other Duralast battery models and one did fit: http://www.autozone.com/selectedZip,.../selectZip.htm
However, I think my car hasn't been performing as well with the new battery - just a buttometer impression. No dyno to backup that claim. Perhaps it's my imagination.
I took a Multimeter and measured the volts from the battery and it measures 12.14 volts (cold reading, engine not running).
Is that too low for a cold reading?
Can a battery that doesn't provide enough voltage negatively effect performance?
Here's the story.
Here's the story.
Here's the story.
Here's the story.
Here's the story.
Wow, somebody revived my old thread.
Anyhow, I chose an Interstate battery in the end that fit but it's heavy. Heavier than stock.
Been thinking about getting this:
![](http://braillebattery.com/images/uploads/gallery/BrailleBatteryB3121.jpg)
It weighs 21 lbs.
Unfortunately it wont fit the stock tray and I'm unsure how to mount it securely.
It weighs 21 lbs.
#40
i would stay away from Optima. me and a buddy got one for his Cutlass.
it was a dud. exchanged it for another dud. they are crap IMHO.
Interstate batteries have been good to me since 92.
this spring i'm putting in a 13lb Odyssey PC 680 ($85).
lightweight, plenty of cranking power, and no corrosion on the terminals.
![](http://dumppix.com/images/6cfef_OdysseyPC680.jpg)
