Transmission temperature?
Old Oct 11, 2012 | 11:59 PM
Victorfriessen's Avatar
Whats the normal transmission temperature range? When do I know if its to hot?
Old Oct 12, 2012 | 10:04 PM
Zaksgt's Avatar
Auto or manual?
Old Oct 13, 2012 | 09:06 AM
Its an auto
Old Oct 13, 2012 | 10:57 PM
Zaksgt's Avatar
Its an auto
I would say 150-175 u can get a trans cooler if you want, trans coolers are good if u have a stall, but u really don't need them on manuals
Old Oct 14, 2012 | 09:43 AM
70MACH1OWNER's Avatar
I have a set of Aeroforce gauges and the trans temp is one thing I monitor. In the winter 145-150 and in the summer when it is 95 outside I have seen 185. But that is running 70 mph on the highway with 4:10 gears.
Old Oct 14, 2012 | 04:56 PM
But my question , when is a auto transmission really considered going to hot because I cee 215 when hot lapping
Old Oct 14, 2012 | 09:18 PM
Zaksgt's Avatar
200 degrees is to hot u need a trans cooler
Old Oct 14, 2012 | 10:44 PM
AlloyGT's Avatar
Mine runs 170. I saw 258 once, after a 20 minute road race session in 95 degree heat. But at the strip, even when hot lapping, it doesn't go over 185. I do have a 3200 stall converter and the PA deep pan. If you're seeing 215 regularly, check your fluid level. Running low on fluid will make it run hotter, and heat is not good.
Old Oct 15, 2012 | 09:06 AM
Thats what I was looking for,more money to spend , haha thanx for the info
Old Oct 23, 2012 | 07:35 PM
ClownPuncher's Avatar
It already has a trans cooler from the factory which is pretty good. I would guess low on fluid and the damage is most likely done at those temps.
Old Oct 23, 2012 | 09:02 PM
What damages occur at that temperature?
Old Oct 24, 2012 | 07:17 PM
My friend fried 2 transmissions shortly after hot lapping and he noticed his trans temp gauge was around that temp. The 2nd trans was a level 10 fully built.
Old Oct 25, 2012 | 12:08 AM
Time for a new trans then,finally!!! Well Im gona drive the **** out of it then just to make sure
CiniZter
25
Apr 28, 2016 05:41 PM
Rando
Sep 30, 2015 12:28 PM
Mustang65bob
Sep 21, 2015 11:30 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
