Transmission Fluid
Old May 11, 2005 | 11:16 PM
hiflyntdwg's Avatar
Do you have any suggestions for which synthetic fluid to put into my 5 speed? Also, what type of fluid for the rear end? Thanks!
Old May 12, 2005 | 09:17 AM
SP_51-F1's Avatar
I wish I had more to add then just bumping this thread. Anyone change over already?
Old May 12, 2005 | 10:38 AM
porsche's Avatar
In my diff i went with redline!
Old May 12, 2005 | 11:06 AM
Firedude's Avatar
I went Royal Purple Trans fluid in the trans. Just over 3 quarts. Mobil 1 gear oil in the diff.
Old May 12, 2005 | 12:18 PM
SP_51-F1's Avatar
At what miles did you change?
Old May 12, 2005 | 07:43 PM
Firedude's Avatar
I switched to mobile 1 in the engine at 700 miles. Just changed the trans. at 2500 miles. You can change at anytime. The diff comes with Synthetic.
Old May 12, 2005 | 09:25 PM
PONY XPRESS's Avatar
"NEO" makes a 7WT synthetic that works for trans & rears. I have used it in road race & circle track cars with HP as high as 650 with no drive train failures.
They also make a 0W-5 engine oil which is also a great product.
Old May 12, 2005 | 11:08 PM
Mongoose's Avatar
Why did you change the oil in the transmissiom and why did you change the rear end lube? Do not understand this move.
Old May 13, 2005 | 12:01 AM
Firedude's Avatar
I change everything over to synthetics as soon as possible. I am sold on synthetics. I did not know the rear came with it already. Even with out using synthetics I would change them all early on. Breakin is done and this stuff is full of metal shaving's. You should of seen the trans fluid after 2500 miles. I am sure I will get flamed on this but its cheap insurance. Has worked for many cars and motorcycles I have had.
Old May 13, 2005 | 11:58 AM
Mongoose's Avatar
Don't know why someone would flame you over this. Your car and $$.
I was just curious as why you did it so soon.
Old May 13, 2005 | 01:10 PM
Firedude's Avatar
Guess I am a little gun shy. I try to stay away from the synthetic debates. I am pretty **** with my rides. I change oil about every 2000-3000 at the most and always use synthetics. I have rebuilt several motors for my self and friends. You can really tell the difference between synthetic and dino oils when tearing down a motor.
CiniZter
25
Apr 28, 2016 05:41 PM
Rando
Sep 30, 2015 12:28 PM
Mustang65bob
Sep 21, 2015 11:30 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
