Traction :/
Old Jun 10, 2011 | 11:02 PM
Stockfoursix's Avatar
Traction :/
So I'm having problem putting down power to the ground. To start I have an 05 gt with an intake/tune from bama, off road h, and custom slp mid muffler. Not bad but I should be able to grab traction.
I recently installed the upr race lower control arms, and a set of relocation brackets. I go out to my local strip on Friday nights and I still spin through 1st and some of 2nd with the stock 3.31s!!
I'm running the stock 235/55/17 tire which I believe is the problem. What tire could I get to correct this that would fit on the stock 17x8 wheel? Is there any other suspension part that would help without buying a whole new set of tires?
Old Jun 11, 2011 | 12:11 AM
Victorfriessen's Avatar
Use the stock tires for burnouts and go buy Nitto Invo 255/40,had the same issue but these tires work great and seem to work decently well on wet also
Old Jun 11, 2011 | 11:32 AM
ski's Avatar
ski
Control arms are designed to eliminate wheel hop, not wheel spin.
You can reduce wheel spin during the launch by slipping the clutch.
Old Jun 11, 2011 | 01:35 PM
Well the clutch deal won't work because I don't have one. :/ I have an auto and with the traction control off it spins bad and with it on all of my power is cut. Lose-lose situation. I am probably going to just have to bite the bullet and buy new tires for the rear. Or maybe a used set of rims and tires for the track.
I'm getting ready to install 4.10s, Detroit rockers, jba lts, and a 3000 stall converter this summer, so traction is going to be more than needed.
Old Jun 11, 2011 | 03:25 PM
Cammed 05's Avatar
Get atleast. 245 width with nitto nt05's. Heat em up good and I promise you won't have traction problems. I only have wheel hop issues now.
Old Jun 13, 2011 | 04:04 PM
Ghost's Avatar
I have a set of BFG drag radials, 275/40-17, old style tread, on stock rims. I can launch between 4500-6000 with minimal spin, on moderately warm tires. I run the stock 3:55 gears with a 5 speed, but I don't have a line lock and so don't do proper burnouts, just light 'em up outside the box as I come up to the line. I would suspect most of your wheelspin can be contained with a good set of drag radials.....
Old Jun 13, 2011 | 07:28 PM
Ghost's Avatar
Talking
Traction :/-tire1.jpg
In case you're wondering what 275/40 looks like on a stock rim......
Old Jun 14, 2011 | 08:13 AM
Thanks guys for the help!
Old Jun 14, 2011 | 11:29 AM
zipperhead's Avatar
M H 275-50-17 . I cut 1.6 60ft with these
Old Jun 15, 2011 | 10:29 PM
Stoenr's Avatar
mmm yes, sticky tires!
All that work into it for the strip and you forgot drag radials
shave some time man!
Sep 8, 2015 10:45 AM
CoyotePremium13
Aug 18, 2015 07:28 AM
tukatz
Aug 13, 2015 09:27 AM
dallasw77
Jul 30, 2004 04:26 PM
