Which track tires?
Old Mar 4, 2007 | 02:08 AM
The_Joker's Avatar
Which track tires?
Just supercharged my car and have terrible traction on the drag strip with my huge wheels. They dont make a drag radial tire for my wheels, so I was going to use my stock wheels when I go to the track and put some good rear tires on them. Is the largest tire I can fit on the stock 17'' wheels a 275? And what tire do you recomend for the track?
Old Mar 4, 2007 | 03:01 AM
2006VistaBlueGT's Avatar
That is the biggest I'd run on the stock wheels. Otherwise you will get bulging sidewalls and less contact patch.
Old Mar 4, 2007 | 11:02 AM
RadBOSS's Avatar
Mikey Thompson, Hoosier ....
Old Mar 4, 2007 | 11:44 AM
rocket88's Avatar
Nitto DR's
Old Mar 4, 2007 | 11:48 AM
don_w's Avatar
You can run the 275/40-17 M/T drag radials (P/N #3743R) or the 26x11.50-17 M/T ET streets (P/N #3743) on 17x8 wheels. Lots of guys doing it.
Old Mar 4, 2007 | 12:46 PM
don_w's Avatar
Originally Posted by rocket88
Nitto DR's
Frankly, those would be my last choice for the track.
Old Mar 29, 2007 | 12:45 PM
Shea's Avatar
Seriously, I could run an 11.5 M/T on a stock rim?
I mean, I know you've raced a lot more than me it just seems like a huge diff between their recommended 11" and the stock 8".
Thanx for your input Don.
Old Mar 29, 2007 | 01:51 PM
don_w's Avatar
Don't take those measurements literally. You need to check the actual specs. The 26x11.50 is actually 26.5" dia, and has a tread width of 9.5". I've never run those tires (P/N 3743) personally, but like I said other guys have. I ran the 275/40-17 DRs on 17x9 wheels (before I switched to 15s).
Old Mar 30, 2007 | 10:15 PM
kampendmk's Avatar
m&h drag radials
I have M&H 275/ 50 /17 they are 28" tall,there 1"taller that stock , ran 8.451 last nite at irwindale it`s a 1/8 mi 60ft 18.88 Installed on factory stock wheels ,got them at brenspeed .com $94.00 each
5.M0NSTER
Sep 12, 2015 08:11 PM
M3hunter
Sep 10, 2015 09:26 AM
Cdvision
Sep 5, 2015 05:22 PM
JTB
Motorsports
Sep 3, 2015 10:50 AM
Kestral
Sep 2, 2015 06:52 PM
