Torque Thrust II Wheels in Stock?
Old Jun 18, 2005 | 05:06 PM
scottma's Avatar
I want to buy Torque Thrust II 20 X10 's for the rear and 18X8.5 's for the front. I went to Discount Tire and they quoted me 6 to 8 weeks. Do you know if anyone stocks these wheels? I waited too long to decide on wheels and my car gets delivered in two weeks. :bang:
Old Jun 18, 2005 | 07:29 PM
scottma's Avatar
No ideas??? :bang:
Old Jun 18, 2005 | 07:52 PM
tmcolegr's Avatar
Not trying to discourage you or stick my nose in your mods but what size tires are you planning on using front/rear? The reason I am asking is that different size tires between front/rear axles can cause issues with the ABS system if the revolutions per mile are to far off. I just went through a lengthy issue with my ABS and the first question Ford ask was if all 4 tires were the same size. I do not know how much variance can be tolerated by the ABS system without causing a problem and Ford would not say. I know several others have used different size tires between front/rear and have not experienced any problems. My only advice is be careful when using different size tires between the front/rear axles.
Old Jun 18, 2005 | 09:16 PM
subzero05's Avatar
they are special order only and NOBODY will have that..it is a custom build for american racing
Old Jun 19, 2005 | 05:58 AM
scottma's Avatar
Thank you. I figured that was the case but wanted to check it out. I guess I should be patient and wait. Thanks again for the reply.
Old Jun 19, 2005 | 08:13 AM
loudog's Avatar
The other thing to consider with the American Racing Torq Thrust IIs is that they are a 2-piece wheel...you may want to search for a one-piece that is similar (they're out there, but are hard to find).
Old Jun 21, 2005 | 02:54 PM
adrenalin's Avatar
Took 8 weeks for mine to show up and then another 6 weeks for them to get me a set with the correct backspacing. Still waiting for my center caps....5 months and counting
SilverBullet13
Aug 13, 2015 09:11 AM
dohc97
Aug 7, 2015 06:27 AM
tdf017
Aug 5, 2015 10:13 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
Mustang-4.6
Jul 27, 2015 05:52 AM
