Time to clean my JLT intake...help
Old Jan 7, 2007 | 11:03 AM
Baginoman2's Avatar
Well i can start to see alot of dirt and dust building up in the filter lines of my JLT intake, and was wondering whats a good product to use to clean the intake? I see this cleaner from the JLT performance site.... http://jlttruecoldair.com/zencart/in...products_id=22
Any good?
Old Jan 7, 2007 | 11:17 AM
70MACH1OWNER's Avatar
Thats what you need to do the job. I have the K&N kit that I have used on my C & L . For 15 bucks you can't go wrong. How many miles do you have on your car?
Scott
Old Jan 7, 2007 | 11:20 AM
dustindu4's Avatar
9 is not my lucky number.
you need that cleaning kit from JLT because it has the oil to reoil the filter. That's why i ordered a kit with my intake
Old Jan 7, 2007 | 11:23 AM
Baginoman2's Avatar
alrighty will do! right now im racking 14,100 miles
Old Jan 7, 2007 | 11:26 AM
SteelTownStang's Avatar
JLT uses S&B filters. The S&B "kit" is the way to go... I'm sure that K&N re-charging kit would be fine as well.
Old Jan 7, 2007 | 03:33 PM
SONICBOOST's Avatar
Can I get this kit at pepboys or autozone?
Old Jan 7, 2007 | 04:42 PM
Stoenr's Avatar
Any good?
+1 on that kit. Its what I got for my JLT. Be prepared for a few hours of down time waiting for it to dry twice.
Old Jan 7, 2007 | 10:33 PM
LordBritish's Avatar
What's the recommended interval for cleaning the filter?
I remember cleaning a K&N filter for an older mustang, and my car performed bad afterwards like it wasnt getting enough air.
Old Jan 8, 2007 | 12:25 AM
RedDragon777's Avatar
i would recommend getting the S&B kit but you can not buy it at autozone you need to order it from JLT or S&B direct but people say the K&N kit works and that you can get at autozone.
oh and LB i think the reason it was like that is you need to clean it twice then reoil and let it sit and dry for a while, they are stubborn and do not clean easy
Old Jan 8, 2007 | 10:27 AM
Machine's Avatar
I have already cleaned and re-oiled my JLT filter using a K&N recharging kit and it works fine. Just follow the directions for drying time and you'll be fine.
The K&N recharging system can be found at any autozone or comparable auto parts place.
Old Jan 8, 2007 | 12:38 PM
mrkabc's Avatar
Will that also work on the C&L intake filter as well?
Old Jan 8, 2007 | 12:43 PM
Stoenr's Avatar
Yup, sure will.
Old Jan 8, 2007 | 02:10 PM
Machine's Avatar
JLT site says every 5-10k miles...but alot's gonna depend on the driving conditions around you and how hard you drive the car.
For instance, I live very close to an expressway that is under alot of construction...dirt and small particles fly around all the time. My filter would get very dirty if it werent for the fact that I hardly drive it very far (yes it's my daily driver but I live where I work). I also take it to the track at least once a month.
I cleaned the filter once at about 6k miles...I'm due for another cleaning now.
2 years = 12k miles....not bad...
Old Jan 10, 2007 | 04:37 PM
Baginoman2's Avatar
hold on! Is it totally mandatory to clean it twice? Because i just finished the cleaning part, waiting it to dry to apply the oil....should i clean it twice?
Old Jan 10, 2007 | 04:43 PM
No.... once a year is plenty. Just depends on your local conditions. If you live in the desert... do it twice a year. If you live in the green belt... once a year is plenty. You be the judge of your conditions.
Scott
Old Jan 10, 2007 | 04:46 PM
Baginoman2's Avatar
thanx man! Man im still waiting it to dry from hosing it down...hmmm might have to wait alittle longer maybe another 20 min.
Old Jan 10, 2007 | 04:47 PM
Got a hair dryer handy???
No, You clean it until in looks clean, then charge it with oil.
Old Jan 10, 2007 | 07:08 PM
metroplex's Avatar
Autozone sells the K&N recharge kits for $9.95 a piece. The cleaner and oil should all be the same whether it is JLT, Summit Racing, Airaid, S&B, etc... It's basically mineral oil last I checked.
Old Jan 11, 2007 | 10:30 AM
Mongoose's Avatar
Beware! If you oil it too much you will screw up your MAP and a new one is expensive. Why not just purchase a new filter from Jay.
