Tidbits of info
Old Apr 25, 2005 | 07:55 PM
169stang's Avatar
We'll, I finally got my car back today with the new differential, 4.30 gears, Stainless Works 1 3/4 long tubes, and 3" exhaust. I go tomorrow to have it dynoed and a custom tune on the SCT. I, will of course, post numbers once I get home.
Some things I picked up....
Never disconnect the battery with the key in the ignition. It will wipe out the computer. It didn't happen, just thought it did. I attempted to install a shift light-NO. I had my mechanic attempt the same-NO. He had to order a wiring schematics for the 05 as well as the complete shop manual-$250. NO ONE had any idea which wire would be the one to hook up to the shift light. Steeda, Paul's HP, some Ford guys, Autometer, MSD and the list goes on, no one has a clue. I look forward to getting the tune, breaking in the gears and getting to the track. I will take some sound clips of the exhaust, once I get it off the dyno. It is pretty loud though. Not too bad at idle or under 3000 rpm. Above 3000, LOUD. I'll keep all those interested posted.
Old Apr 25, 2005 | 07:59 PM
outdoorstom's Avatar
We're all ears! Can't wait to see the numbers and hear the exhaust!
Old Apr 25, 2005 | 08:01 PM
169stang's Avatar
10:30 tomorrow! anxious
Old Apr 25, 2005 | 08:06 PM
wild stray's Avatar
[quote=169stang,April 25, 2005, 6:58 PM]
You prolly won't get a good dyno this soon after gear install.
Paul
Old Apr 25, 2005 | 08:12 PM
Vegasjay's Avatar
I've been wanting to get the Ford service manual for the 05 myself. Do you have a contact number to get it? Congrat's on the part's, I bet it sound's great! Good luck on your dyno tuning, hope it goes well.
Old Apr 25, 2005 | 08:19 PM
max2000jp's Avatar
Vegas Jay, I just noticed you 1/4 time in your sig. Nice trap speed there, what were the conditions like?
Old Apr 25, 2005 | 08:24 PM
169stang's Avatar
As much as I hate to admit that your right Paul, I have to get it tuned though to get the computer right in the head. My other dyno pull where I hit 294 rwhp was 10 mins. after 4.10's were installed. It'll mesh good then I'll go back in a month to get her dynoed again. The mechanic that does my tedious work was surprised that he was able to order the manual as well. He will be getting it in a few days. I'll see if I can get the info for you.
Old Apr 25, 2005 | 08:37 PM
wild stray's Avatar
Good luck tomorrow. I'll be interested in your pulls as usual.
Paul
Old Apr 25, 2005 | 08:51 PM
Blk05GT's Avatar
Very nice. Are you running cats with that exhaust set up?
Old Apr 25, 2005 | 09:15 PM
Vegasjay's Avatar
It was a nice night, 65 degree's clear and calm. Humidity was real low, mabey 10 % or so. The track was in great shape, I followed all the great advice from here, such as staying out of the water box, lowering my launch RPM's, feathering the clutch at launch etc. I launched at right about 3000 RPM's, hooked the clutch just right and power-shifted at about 6200 RPM's. The tire's broke loose on the 1-2 shift, 2-3, and 3-4! Everything finally came together...
Old Apr 25, 2005 | 09:30 PM
Vegasjay's Avatar
That was on stock tires, MT's and Ram Clutch are the next performance Mod's. I installed my CDC ducktail and I am painting the 3-D Carbon louver's right now, pic's in a couple day's....
Old Apr 25, 2005 | 09:36 PM
Refonbass's Avatar
vegasjay.. you're tires broke loose on the 3-4 shift?
with 312rwhp?
Old Apr 25, 2005 | 09:54 PM
Vegasjay's Avatar
with 312rwhp?
Yup, like I said everything came together just right. I could only replicate it one more time, so I'm still polishing my driving skills.... :bang:
Old Apr 25, 2005 | 09:55 PM
169stang's Avatar
No cats. It's worth maybe 3-5 hp. If it gets annoying with how loud it is, I may put cats on it.
Old Apr 25, 2005 | 09:57 PM
169stang's Avatar
with 312rwhp?
These 05's are harder to run at the strip than it may sound. I'm at 294 rwhp and when I put in the new clutch, it was breakin loose at every shift. It would have been more scary with 312rwhp. I'm taking baby steps.
Jays' got a bigger set.
Old Apr 25, 2005 | 10:01 PM
Refonbass's Avatar
hmm.. i couldn't even brake loose the tires on my buddies 600whp viper on the 3-4 shift
but if you say so I guess its possible.
in my 05 I have JLT CAI, SCT tune, SLP loumouth exhaust, Steeda U/D pullies, frpp 4.10 gear set. and some weight reduction and I'm lucky to chirp on the 2-3 shift.
Old Apr 25, 2005 | 10:11 PM
169stang's Avatar
I have a different clutch that hits really hard as well as an upper third link which helps it squat harder. The other problem is that my suspension was too soft, so I lowered it 1" with Steeda sport springs which really helped out a lot. I'm waiting on aftermarket adjustable coil overs. Besides all that, if you have the traction control on, you won't break loose running down the track as well as get the best possible time your car is capable of running. Above all that...I say so.
Old Apr 25, 2005 | 10:29 PM
max2000jp's Avatar
I can only chirp 3rd every so often when the clutch is really gripping. First to second I am able to rip the tires loose. If I nail it in first at a steady 3K rpms, my car just goes. I figure I should be around 285-290 rwhp with my mods.
Old Apr 25, 2005 | 11:27 PM
Vegasjay's Avatar
Sometime's horsepower and gearing can take a backseat to really knowing your car well and hitting the "sweetspot".... I can "chirp" the 1-2, 2-3 all the time with no problem's. The 3-4 was a two time adventure, maybe a little something on the track as it's only happened there, but both time's it happened it lead to my best time's at the track. Which lead's me to believe I was finally hook'n it up just right...Time will till I guess.
Old Apr 26, 2005 | 12:19 AM
luckyeod28's Avatar
I am looking forward to finding out your results. Tell us what you think of the 4.30's, and do you drive this car everyday.
