Temp Gauge not working
Old Aug 20, 2007 | 05:09 PM
SpeedRoush's Avatar
I have an O6 GT with a CAI and sometimes when I crank the car up the temp gauge remains in its position as if the motor is off. Sometimes it will read exceptionally high around the 3/4 mark. Most of the time it just doesn't work at all. Any ideas on what i can check myself?
thanks
Old Aug 20, 2007 | 05:21 PM
tmcolegr's Avatar
Are you sure you don't have an air pocket in the cooling system?
Old Aug 20, 2007 | 05:55 PM
don_w's Avatar
Even when it's working right, it's still a POS idiot needle. It will stay in the middle from 180 degrees up to 230 degrees.
Old Aug 20, 2007 | 06:04 PM
RedDragon777's Avatar
take it in for warrenty then buy an Autometer guage, i am personally going to buy a temp, trans temp, and fuel press
Old Aug 20, 2007 | 06:22 PM
dustindu4's Avatar
9 is not my lucky number.
The only time the needle will move is if the car overheats, it will peg and turn red. Otherwise it stays in any position it wants. It's a dummy gauge
Old Aug 21, 2007 | 11:43 AM
ChevyKiller's Avatar
If you get a trans temp guage make sure to tap it directly into the pan. I had tapped mine into the trans lines and then it was useless. I was reading temps coming back from the motor and they were always in the 210ยบ-225ยบ range.
They are uselss anywhere except tapped driectly into the trans pan.
Old Aug 21, 2007 | 01:55 PM
i am going to buy the PA pan and i will take your advise and tap the pan before we install it
samjluck
Sep 17, 2015 10:24 PM
50Cal
Sep 17, 2015 06:43 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
GMAYS
Sep 10, 2015 06:19 AM
