Swapped out the Precision Gear 4.10's for FRPP's
Old Sep 14, 2005 | 10:30 AM
Clem's Avatar
I though I'd post a happy ending to another noisy gear story.
Yesterday we swapped my annoyingly whiny Precision Gear 4.10's for a set of FRPP 4.10's. My installer ended up using the same exact shims and spacers and once again got a perfect pattern on the install. The result, however, was night and day.
The new FRPP's make almost no noise. I do get a little tiny bit of whine in the 50-60 mph range but it's a small fraction of what I got with the Precisions. Perfectly liveable, whereas before, I couldn't drive for long without getting really pi$$ed off and headachy. I had all but stopped driving it for fear of road rage against my own car!
The FRPP's backlash is from .0065 - .008.
The Precision's came up anywhere from .007 - .011, which = Sloppy!
Apparently the Precision's were anything but. Surprising since they have a rep a being a quailty gear. We'll be sending those back to the manufacturer hoping for a full refund. I won't hold my breath though...
I'm just happy to have her back!
Old Sep 14, 2005 | 10:55 AM
outdoorstom's Avatar
Always nice to hear a happy ending. Welcome back to the world of sane people.
Old Sep 14, 2005 | 11:40 AM
Clem's Avatar
It's good to be back!
Old Sep 14, 2005 | 01:31 PM
don_w's Avatar
Glad to hear all is well now, Adam. I have had my FRPP 4.10s for over 2 months now and no complaints whatsoever.
Old Sep 14, 2005 | 01:38 PM
Chaotic Bliss's Avatar
My FRPP whine like crazy. I will be going back soon to see if they can be adjusted.
Old Sep 14, 2005 | 04:11 PM
Clem's Avatar
I feel for ya, man. I didn't like my car very much with all that noise coming from the gears. I do strongly believe that these '05 Stangs are very sensitive to noise and vibration coming from the differential and you will need a spot on install as well as some good old fashioned luck. I looked at the pattern from the noisy Precision's that we took out and the it looked just as good as the quiet FRPP's. Didn't make sense, but I'll take it. Good luck getting it resolved. There is hope.
Old Sep 14, 2005 | 04:13 PM
Route 66's Avatar
I'm sure I'll get flamed, but why not just leave the original gears on. Do you plan on racing? If so, then I suppose I could understand.
Old Sep 14, 2005 | 05:09 PM
luckyeod28's Avatar
Why??????
BECAUSE ITS FUN!!!!!!!!!!
Old Sep 14, 2005 | 06:02 PM
don_w's Avatar
Only every week (or as often as possible)!!
Old Sep 14, 2005 | 06:24 PM
hauss1's Avatar
What is the difference in the original gears and the 4:10 gears? Does it help the car's performance significantly? Also what is the whine everybody is talking about? The reason I ask is b/c someone suggested this as a mod to me in a previous post.
Old Sep 14, 2005 | 06:25 PM
eighty6gt's Avatar
Mustang + 4.30's = Tire burning mayhem.
Gear "whine" is a bit of a misnomer. It is actually the gear faces slapping together. Hypoid gears are supposed to be in constant contact to stop this noise from happening... if they are not properly manufactured or installed they will whine at certain RPM's. The mechanical effect is always present, but can only be heard when the frequency of the noise matches a resonant frequency of one or more components.
Old Sep 14, 2005 | 10:40 PM
clockworks's Avatar
I want to get some 3.90's because I think 4.10's will be too much for me. I think only Motive makes 3.90's. How reputable are they? What do you think my chances of "gear whine" are? I'm probably going to get it done in 2 weeks, I hope I'm not making a mistake...
Old Sep 14, 2005 | 10:53 PM
don_w's Avatar
Originally posted by clockworks+September 14, 2005, 9:43 PM--><div class='quotetop'>QUOTE(clockworks @ September 14, 2005, 9:43 PM)</div><div class='quotemain'>I want to get some 3.90's because I think 4.10's will be too much for me.
[/b]
There's only a ~5% difference between 3.90s and 4.10s... FWIW
<!--QuoteBegin-clockworks
@September 14, 2005, 9:43 PM
[/quote]
Based on what I have read on these forums... about 50-50. Good luck!!
Old Sep 14, 2005 | 10:56 PM
clockworks's Avatar
Now why did you have to go and tell me that...
Ok, so stock are 3.55. What's the percent difference between stock and 3.73's, 3.90's, and 4.10's?
Old Sep 14, 2005 | 11:07 PM
don_w's Avatar
Each step up is around 4.5% to 5%.
Old Sep 15, 2005 | 12:01 AM
clockworks's Avatar
Sweet, thanks. 10% sounds perfect to me...
Old Sep 15, 2005 | 05:18 AM
Clem's Avatar
If you do a fair amount of driving above 70 mph, the 3.90's might be just about right for you. My car with the 4.10's is not driven daily, but if it were I would consider any more than 4.10's to be too much. I bought my car strictly for entertainment purposes and I think my gears are perfect for that. On an every day basis, I'd be giving it more thought.
The Motive gears are less expensive than some of the other brands, but based on what I've read, they aren't more problematic. You may also have a slightly better chance of a quiet install with the 3.90's.
Old Sep 15, 2005 | 08:29 AM
jlb's Avatar
jlb
I've been thinking of the 4.10s myself. I have read that the frpp gears are the best and quietest out there, but it sounds like the set up is the KEY. I'd give up the top end, for sure, for some stop light to stop light, back in your seat action!
Rando
Aug 25, 2021 11:12 AM
Jul 8, 2016 08:53 AM
Rando
Sep 30, 2015 12:28 PM
Ray11
Sep 25, 2015 12:43 PM
Grabber5.00
Sep 13, 2015 06:53 AM
