Supercharger questions "tuner kits" : Vortech and Paxton
I'm going to assume that tuner kit has everything needed except;
- injectors
- fuel pump
- tuner (predator or x2)
I HAVE a tuner so thats not an issue.
Injectors are cheap and fuel pumps are not very pricey...
To get in the door.... S-trim 2720$ on blow by racing's website
Anyone have any experience with a tuner kit?
- injectors
- fuel pump
I was going to get the tuner kit and then hunt down some nice injectors and a fuel pump.. and after that, install the kit and save up for the intercooler/aftercooler.
I wonder what the differnce is between s trim and t trim?
vortec's website it down right now, being reworked so i cant check right now.
You likely won't need a mass air, even with a tuner kit. Most kits like the Paxton come with a larger diameter mass air sensor and fitting, even the tuner kits. Just make sure you do or don't need one before you go buying one with that bonus money.......
What makes you say that Forced? Vortech and Paxton certainly market the T-Trim and Novi 2200's for stock engines. I'm having a Novi 2200 installed on my block with the base pulley, are you saying I'm in for problems or are you referring to those who go for bigger pulleys?
Not any problems...it's just the S-Trim is good for stock apps...sure the T-Trim will work, but it costs more. If you are planning to do any motor work...you could step to the T-Trim. The S is good for 680ish HP.
So for the vortec kit I'll need to aquire..
Tuner kit from blow by racing
MAF?
tuner (i have one already)
Injectors (which size?)
Fuel pump
Any help you can provide forced is appreciated in reguards to the vortec kits.
I can almost feel that box being unwrapped now.
MAF?
Fuel pump
The more I watch and listen to that darn video, the more I want a Magnacharger. Roots or not, its a good deal for the money, looks great, sounds great, and shouldn't throw a rod thru the block at the base level.
Just thought I'd throw this out there because people seem to think roots blowers are old technology and only stupid people would choose them. Yes it's less efficient in developing boost than the alternatives, but on the plus side a roots blower doesn't technically compress the air at all, it just forces it into a confined space. That means if you aren't at full throttle it isn't doing any work. It's only when you're aproaching WOT that it starts to build up pressure in the intake manifold. All this means that for the 99% of the time that you arn't at WOT you're burning less gas than the twin screw guys. After all that's why most manufacturers still use roots blowers even though "better" alternatives are now available.
