Stock Cam Specs ...
Old Jan 13, 2006 | 06:26 AM
2005RedGT's Avatar
Does anyone have the stock cam specs for the in the 2005 Mustang 3v?
-Bryan
Old Jan 13, 2006 | 08:39 AM
rhoover2's Avatar
Hey Bryan how is the re-build going? Haven't heard from you for a while. Must be pretty busy getting the new motor ready. I heard that Comp is getting pretty close with thier new cams.
Old Jan 13, 2006 | 08:58 AM
2005RedGT's Avatar
Cams and Heads are ready, and back in the shop, as of yesterday. I should have an update today with the new flow specs and cam specs. I "assume" that next week, they will install the eingine inthe Stang and hopefully tune by next weekend.
-Bryan
Old Jan 13, 2006 | 09:29 AM
SixtySix's Avatar
Looking forward to seeing it run again
Old Jan 13, 2006 | 12:55 PM
SC67Stang's Avatar
Good to hear you are getting the car back together again.
Hope it goes smooth.
Old Jan 13, 2006 | 05:40 PM
The Boss Hog's Avatar
-Bryan
Bryan,
From page 98 of the Feb. 06 MM&FF; intake lift = .439, exhaust =.436, no info on duration or other specs.
The Boss hog
Old Jan 13, 2006 | 06:01 PM
2005RedGT's Avatar
Fantastic The Boss Hog. Thanks for the info
-Bryan
Old Jan 13, 2006 | 10:57 PM
FordRacing's Avatar
Bryan,
Here you go, Taken from the service manual.
Can't wait to hear how the new setup is.
Camshaft
Theoretical valve lift @ 0 lash — intake 11.166 mm (0.439 in)
Theoretical valve lift @ 0 lash — exhaust 11.066 mm (0.436 in)
Lobe lift — intake 5.520 mm (0.217 in)
Lobe lift — exhaust 5.506 mm (0.217 in)
Allowable lobe lift loss 0.00127 mm (0.005 in)
Journal diameter 28.607-28.633 mm (1.126-1.127 in)
Camshaft journal bore inside diameter 28.657-28.682 mm (1.128-1.129 in)
Camshaft journal-to-bearing clearance 0.024-0.075 mm (0.001-0.003 in)
Runout 0.03 mm (0.001 in)
End play 0.0050-0.250 mm (0.0002-0.009 in)
Fords4Ever
2011 - 2014 GT/CS
21
Mar 1, 2021 12:22 PM
SMOKE46
Sep 6, 2015 09:40 PM
dbent15
Sep 5, 2015 12:15 PM
whowasthat
Sep 3, 2015 08:48 PM
