Steeda Underdrive Pulley install (with pics)
Old May 29, 2007 | 09:55 AM
Originally Posted by pville piper
Great write up as usual. About how much time did it take?
Around 5 hours, but that was doing the CMCV Deletes at the same time. Picture taking and lunch included.
Originally Posted by MrClean
Were the CMDP's from CR the billet Steeda ones, or the FRPP-style ones? Saw them partially in the 1st pic...
Originally Posted by mustangfan123
Tacobill's are the FRPP style.
Originally Posted by GRAYPNY
Driving impressions after the install?
Engine rev's up quicker in neutral, so it must have lifted some of the accessory drive drag.
As far driving around, in my short (and not too crazy) test drive, I can't say that there's a world of difference. Only that it feels just as strong in the bottom end before this mod. Keep in mind that it's coupled with the CMCV Deletes.
Like I mentioned in the CMCV post, these 2 mods are being overshadowed by the 4.10's. Even though I'm sure that the UPD's and CMCV's will show an improvement on the dyno, all the neck snapping is coming from the gears.
Originally Posted by Juice
Now the really important question, can your alternator keep up with the electrical loads and how does the AC work afterwards? These are my concern with the UD Pulleys.
I haven't cycled the A/C on yet.
I do know that Steeda engineered these pulleys with Ford Engineers. So that's got to be a plus.
Originally Posted by Lowe!
Good point! I actually put my manual in 4th gear, and the engine didn't turn over very far.
I had mine in Reverse.
I thought about trying other gears, but then decided to pull the fan for the write-up. At least that's my story.
Old May 30, 2007 | 02:52 PM
officespace56's Avatar
I hear if you have after-market subs put in the trunk, you will not have enough power for both the pulleys and the subs, you have to pick one or the other. Is this true?
Old May 30, 2007 | 03:07 PM
I haven't a clue.
Maybe post this question in the Audio Mods section. Some guys with high-powered stereos and amps can better answer your question.
Old May 30, 2007 | 07:53 PM
PIKE2244's Avatar
So do you think you will have any problems if you take it into the dealer?
Old May 30, 2007 | 08:13 PM
highvolts's Avatar
Two Questions,
What kind of gloves are those and where do you get them?
What brand of pully puller is that?
-Jason
Old May 30, 2007 | 10:25 PM
Doubt it. As long as the warranty issue isn't related to the pulleys, should be non-issue (that goes for the rest of my mods).
Gloves are HyFlex 11-600. http://www.ansellpro.com/index.asp
I believe there's several online suppliers that you can order from.
Gear puller and harmonic balancer install tool are from Blue Point (I think they're a Snap-On division).
Attached Thumbnails Steeda Underdrive Pulley install (with pics)-pulley_tools.jpg
Old May 30, 2007 | 11:46 PM
one_mean_marine's Avatar
Congrats on the install on the UDP's! & CMCV deletes! My only question is what took ya so long for these mods!LOL I noticed a slight difference on on reving the motor after installing my UDP's . As always bill nice write up. I still need to get the delete plates. Just waiting for Fast Perf intake to come out this summer and see what the gains are with it before i get the deletes since their intake will have them on em.
Old May 31, 2007 | 07:27 AM
Got the Part Numbers from the Snap-On catalog.
YA9740B Harmonic Damper Pulley Puller
YA188C Harmonic Balancer Installer
I was on the fence with these 2 mods. Recently decided, what the heck, and got them. After I get my C&L Racer, that'll be about it for simple bolt-ons.
Old May 31, 2007 | 10:54 AM
NYNY53's Avatar
Here's a question for you Billster:
Any advantage to doing the pulley's and delete at the same time?
Not sure I have the energy to do them both at the same time but individually I think I could handle ha
Good stuff Bill
And how about those valve covers.........................still thinking on those?
Old May 31, 2007 | 11:16 AM
About the only advantage is having the factory air tube and box out of the way when performing both mods. Other than that, no real advantage as they can be done seperately.
In hindsight, I should've just taken a heatgun to the new pulley instead of boiling it. But, to go through the experience was worth it.
And, I probably wouldn't have wiped down the pulley with brake cleaner because their wouldn't have been any melted plastic on it. Thus, my pulley would've still been black. But, I do like the look of my shiny pulley though, just have to keep it wiped down with WD40 so it won't start rusting like the factory pulley.
The order is already in for my FRPP camcovers.
Old May 31, 2007 | 01:01 PM
NYNY53's Avatar
Ok you didn't waste much time on that
Then what color did we order for those CamCovers? Something freaky or something along the lines of your current color scheme?
Trying to keep up with you Bill is useless
Old May 31, 2007 | 01:46 PM
cds06stang's Avatar
Maybe red????
Old May 31, 2007 | 01:58 PM
Originally Posted by cds06stang
Maybe red????
Phil, trying to keep up is futile. I have a 15 month head start on you!
M-6582-C543V
Old May 31, 2007 | 01:59 PM
NYNY53's Avatar
You know there's red someplace on these new CamCovers, thats a given lol
Fooled again "Polished" e-gads Making pretty are we Bill The garage Queen label is so justified
I'm in it for the long haul so I'll just keep chipping away Bill, although I might not close the gap I will get closer to you. lol
Old May 31, 2007 | 08:22 PM
NJ3's Avatar
NJ3
With all your new mods the C&L Racer should be an improvement over the K&N. Hmmm, but I won't be able to say mine is bigger than TacoBill's.
Old May 31, 2007 | 10:51 PM
Originally Posted by NJ3
... the C&L Racer should be an improvement over the K&N.
That's what I'm banking on!
Old May 31, 2007 | 11:23 PM
mustangfan123's Avatar
You should've gained about 20hp with K&N + Tune vs. 25-30hp C&l Racer + Tune
Old Jun 1, 2007 | 01:44 PM
BuzzyStang05's Avatar
Yeah, me too, didn't do these right away. I'm about two months ahead of you on the CMCV's and UDP. I put the balancer pulley in a small toaster oven cranked all the way up.
As far as no more simple bolt ons...don't forget one-piece driveshaft and adjustable control arms!
Old Jun 3, 2007 | 10:04 AM
Yeah, I should've just taken a heat gun to the pulley just to simplify things. Although I kinda like the shiny effect of the pulley when I accidentally wiped all the paint off!
I'd entertain the 1 piece driveshaft, but I have 2 concerns..
I wonder if it will have clearance to the MGW Shifter?
Until I stop reading posts about the vibration issues (at hwy speeds), I don't quite get that 'warm & fuzzy'. Could be the way they installed it though..
Old Jun 4, 2007 | 11:14 AM
  #40
just wondering, i noticed that the shaker was off when you did the install? was that a pain?
