Steeda Ultralite spring install complete!
Old 3/5/06, 12:12 AM
Here's the installation of the Steeda Ultralight lowering springs on my 2006 GT coupe with the (64W) Polished Bullitts.
Baseline measurements were taken before the install.
DRIVERS SIDE
FRONT (GROUND TO Wheel Well CENTER): 28 5/8"
REAR: 29 3/8"
FRONT (TOP OF TIRE TO WW CENTER): 2"
REAR: 2 3/4"
PASSENGER SIDE
FRONT (GROUND TO WW CENTER): 28 7/8"
REAR: 29 7/8"
FRONT (TOP OF TIRE TO WW CENTER): 2 1/4"
REAR: 3"
PART 1
REAR INSTALL
Rear was jacked up from the rear differential (pumpkin) and jack stands placed under the frame.
Note: Use caution when placing the jack pad under the pumpkin. The rear differential cover can be easily dented and damaged (can potentially cause a leak) if the jack pad isn't positioned properly. There's a flat section on the pumpkin to jack from just forward of the cover. Using a piece of 2x4 on the jack pad may help.
Removed the anti-rollbar clamps (2 places each, both sides).
Note: Another option is to remove 2 bolts (1 each side) from the swaybar link support to body (see 4th pic down).
(optional)
Removed brake line support bracket (both sides).
Removed lower shock mount bolt (both sides).
Slowly dropped rear pumpkin low enough to remove the OEM springs (both sides, had to push down at outer end of axle a little, near disc brake, to give that extra room to pull the spring out).
Comparison between stock OEM rear springs and the Steeda Ultralites.
Picture of lower spring mount on axle.
Install the new springs on both sides, then jack pumpkin back up to align the lower shock mounting holes. Re-assemble what you removed/disconected from the above steps.
Picture of new Steeda spring installed.
Note: Tight wound coil going up into the body, loose wound coil toward axle. Steeda directions does not address spring orientation. I called Steeda Tech Support to validate correct position. Also, there's no mention on which way to orientate the coil pigtail ends, I just positioned the Steeda coil ends where the OEM ones were.
Installation complete.
Ready to lower jack. Rear is done!
See Part 2 for front install.
Old 3/5/06, 01:09 AM
PART 2
FRONT INSTALL
Front end jacked up.
Lift and jack placement.
Note: I now place the jack stands on the ends of the front crossmember support, not far back on the frame as in the pic below.
Removed brake line clamp on strut housing (both sides). (10mm bolt I think)
Break loose upper front anti-rollbar link from strut housing (both sides).
Removed the anti-rollbar link attachment nut, you may have to use 2 wrenches to remove this nut (both sides).
Remove ABS electrical wire support plastic clamp (Christmas tree type, one way). This was a pain to pull out without breaking it. Needle nose pliers help. (Both sides)
After removal of the 2 lower strut bolts and nuts from the spindle, support brake assembly with some rope to lessen the strain on the brake line (both sides).
With nothing attached to the lower section of the strut, have someone support it while the 4 nuts on top of the strut tower are removed (one side at a time). With care, ease the strut assembly out from the wheel well.
Picture of strut assembly out.
Picture of strut assembly being positioned into spring compressing tool.
Take note that the half circle cutout on top of the bearing cap is in line with the hole in the bottom perch. THIS IS THE ORIENTATION WHEN YOU PUT IT BACK TOGETHER!
With the springs compressed, remove top strut bearing cap.
I think the center nut requires a 22mm wrench.
Picture of strut bearing cap removed.
IMPORTANT: If the bearing cap comes apart or you have suspicion that some of the ball bearings may have popped out from the race, you'll need to re-assemble it. Don't worry, it's not a big deal. Lay down a clean rag on the floor and take apart both halves of the bearing cap (it just clips in together). Clean off any ball bearings that may have fallen out, re-grease, and place back into the race. Clip back together.
Remove lower black plastic coil protector/isolator off of OEM coil and install onto new Steeda coil in the same position. Note: Steeda had installed a clear plastic protector on the coil about 2 coils up; we left it alone.
This step is required for ALL spring swaps, not only the Ultralites.
Picture of stock OEM front spring compared to the Steeda.
With the new spring into position, it's once again compressed to allow the installation of the top bearing cap. Note: Tighten the nut all the way down and align the factory torque stripe.
Picture of strut assembly installed back into car.
Once the 4 studs come up through the strut tower, hand tighten the nuts on them to keep the strut in place while you attach the 2 lower strut bolts to the spindle.
Once the 2 strut bolts are tight, position the center strut shaft within the center hole in the tower and tighten down the 4 nuts (hint: You maybe able to see marks in the paint where the nuts were, just postion them in the same place).
I put a couple of 2x4's under the front tires before lowering the jack, just incase I couldn't pull the jack out from under the car (since it's lower now). Ended up not needing them. But, if you're installing a lower (than the Ultralite) spring kit or have an aftermarket spoiler, you most definitely want to do this at the minimum, you'll most likely have to drop the wheels on something higher to get the floor jack out. Just lower the jack slowly and see what's going on.
After the wheels were on the ground, my son went for final wheel torque (with a little help).
So here we go with some before/after pics:
BEFORE
AFTER
(other side)
Note: This spring install was done in March of 2006. That's why my car looked a little 'bare'. This is how she sits now...
All bolt/nut torque specs can be found here:
FRONT SUSPENSION: Work Instructions
REAR SUSPENSION: Work Instructions
Final drop dimensions:
DRIVERS SIDE
FRONT (GROUND TO Wheel Well CENTER): 28"
REAR: 28 3/8"
FRONT (TOP OF TIRE TO WW CENTER): 1 5/8"
REAR: 1 3/4"
PASSENGER SIDE
FRONT (GROUND TO WW CENTER): 28 1/8"
REAR: 28 7/8"
FRONT (TOP OF TIRE TO WW CENTER): 1 3/4"
REAR: 2"
REAR AXLE POSITION (plumb bob from center of WW to center of wheel cap (Pony logo); dimension is between line to center wheel cap):
BEFORE
DRIVERS SIDE: 1 7/16"
PASSENGER SIDE: 1 1/4"
AFTER
DRIVERS SIDE: 1 3/8"
PASSENGER SIDE: 1 3/8"
Adustable panhard bar NOT required! Even if it were a little off, I don't think it's a big deal unless you're running some wide tires out back, then the axle shift will be apparent.
FRONT GROUND CLEARANCE AFTER LOWERING:
CENTER OF CAR: 7 3/4"
OUTER ENDS OF LOWER BUMBER: 7"
How's the ride? Great! To be honest, it's only slightly stiffer than stock. If you were to jump into the car and started driving, and not knowing it was lowered, you probably wouldn't notice the difference in ride quality.
Overall drop is not as drastic as other kits (ie. Eibach Pro) and it did retain the slight forward rake, which I happen to like.
I purchased these adjustable camber bolts just incase my camber was off, but ended up not needing them.
Here's my alignment data:
When checked at max positive camber with the factory strut bolts in place, drivers side measured in at -1.0 degree, passenger side measured at -1.3 degrees.
Caster was also verified.
It was suggested to me to bring in the drivers side to -1.3 degrees to match the other side in lieu of installing the adjustable camber bolts.
Rationale: Based upon my annual mileage and driving conditions, I won't see any appreciable tire wear for several years (or several thousand miles). Another factor was not driving in the rain, which negative camber can introduce unwanted hydroplaning.
Track camber settings can range from -1.5 to 2 degrees of negative camber. At -1.3 degrees, I'm at 'agressive street' driving.
Old 3/5/06, 01:21 AM
scramblr's Avatar
Great write up Bill. Just in time too as I'm going to be doing this in about a month. Thanks!!!!
Actually, I have a question. Why did you go with the Ultralite vs the Sport?
Old 3/5/06, 01:29 AM
<div class='quotetop'>QUOTE(scramblr @ March 5, 2006, 12:24 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Thank you. Documented all this for my fellow TMS members!
Went with the Ultralites for 2 reason:
1. Said to have a more softer ride (compared to the Sport)
2. They are on sale!
Drop is said to be the same between the two.
I don't do any track/autocrossing, so I didn't see the need for the stiffer Sport springs.
btw- I added 1 more 'after' pic in my edit.
Old 3/5/06, 01:38 AM
scramblr's Avatar
Oh heck yeah, that second pic really brings out the change. It's like I'm looking at my car except for the Blades. :-) Thanks for the input!!!!
Old 3/5/06, 01:44 AM
89Trooper's Avatar
Wonderful write up! Looks great... I'll be adding those springs to my shopping list!
Old 3/5/06, 01:56 AM
scramblr's Avatar
Sorry, another question. Guessing you didn't run into any camber adjustment issues as far as ligning up, right? Is every car different or is it due to how much the car is lowered? Being in Germany, if I get into the middle of the install and it doesn't line up, I'm screwed. Thx...
Old 3/5/06, 02:07 AM
<div class='quotetop'>QUOTE(scramblr @ March 5, 2006, 12:59 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Alex-
I'm no expert on front end alignments, but I do know that the amount of camber adjustment is directly related to how much the car is lowered.
So, a mild front end drop (like mines) will/should require minimum adjustments to bring it back into specs.
For you being in Germany, I would look for a track set-up alignment shop that's familiar with corner balancing. These shops won't need any Ford spec numbers and will align your front end with measuring tools and gages.
Old 3/5/06, 02:16 AM
scramblr's Avatar
Cool, thanks Bill. I just don't want to "not" have all the parts I need and then get stuck, i.e., camber adjustment plates.
Old 3/5/06, 04:13 AM
tom281's Avatar
Great write up, great pics, great car.
Great job!!
Thanks,
Tom
Old 3/5/06, 04:16 AM
scramblr's Avatar
You sold me Bill...Bought today!!! Got the Pulley Kit while I was at it as well... [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img] [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img] [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img]
Old 3/5/06, 06:06 AM
Machine's Avatar
excellent write up...
Old 3/5/06, 07:00 AM
OKCMustangGT's Avatar
Looks great Bill, excellent write-up.
Old 3/5/06, 07:15 AM
mhk
mhk's Avatar
Great job! Just what I was looking for. Question: Someone told me that it's better to get different shocks when you lower your car. Is there any truth in that?
Old 3/5/06, 07:28 AM
tkogt's Avatar
nice job, i like pictures [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img]
its funny , the tolerances ford has?
my rear end was centered under the car before i lowered it.
after i was done i NEEDED an adjustable panhard bar, to recenter the rear end.
as a side note i got one with solid rod ends and it helped with the squirm in the rear suspension.
did you measure the travel in the rear end when you were done?
i only have 3/4 inch at the bump stop cushions and was thinking to cut them down
jay
Old 3/5/06, 07:40 AM
Mustang69-05's Avatar
Awsome write up!!!!!! Cool pix! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old 3/5/06, 07:44 AM
scramblr's Avatar
<div class='quotetop'>QUOTE(tkogt @ March 5, 2006, 3:31 PM) Quoted post</div><div class='quotemain'>
jay
[/b][/quote]
Jay,
Which springs did you use and how much did you lower it? I'm going to lower mine first and then see if I need a panhard bar.
Old 3/5/06, 08:01 AM
tkogt's Avatar
<div class='quotetop'>QUOTE(scramblr @ March 5, 2006, 8:47 AM) Quoted post</div><div class='quotemain'>
Jay,
[/b][/quote]
i put the frpp suspension pack on the car and it lowered it 1.75 inches ft and rear. it looks to be slightly lower than the red one in this thread(the ft wheel opening is only 1/2 inch above my ft tires,235/50/18's)
springs/shocks/struts/sway bars/strut tower brace.
h.p. motorsports adjustable panhard bar w/solid rod ends
jay
Old 3/5/06, 08:04 AM
scramblr's Avatar
<div class='quotetop'>QUOTE(tkogt @ March 5, 2006, 4:04 PM) Quoted post</div><div class='quotemain'>
jay
[/b][/quote]
Thanks. Word is that if lowering more than 1", new shocks are in order. From what I've read the rear end staying centered is a crap shoot....
Old 3/5/06, 09:51 AM
Baginoman2's Avatar
nice going TacoBill, she looks awesome!! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img] [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Quick Reply: Steeda Ultralite spring install complete!
