Steeda Tri-ax Installation
Does anyone have a nive how-to for installing the Tri-ax shifter? I checkout out TacoBill and he doesn't have this particular mod. Any info would be greatly appreciated, even if it's just some tips.
Thanks guys.
-Kev
Thanks guys.
-Kev
1. no need to remove driveshaft
2. put shifter through hole in two pieces and put the two allen screws in while under the car.
3. have wife/gf hold shifter piece while you put the arm on.
4. use locktite on all those bolts
The install is pretty easy...
what city/state are you located in?
Located in Bristol, RI, about 20 min out of Providence. Wish I was in southern Cali for two reasons: 1- no winter months to worry about = 365 days/year pure mustang enjoyment and 2 - seems to be where all the dealers/vendors are. Stupid RI...
Kevin, I just did mine a few weeks ago and I took a boat load of pictures with the intentions of doing a write up but I just have not had the time. 06GT pretty much has it down in a nutshell though. It is only 4 bolts to take out the stock and 6 (2 allen screws) for the install. Doing it with the driveshaft in is not hard, just takes a little paitence. I'll try to do the write up this weekend.
-Kev
Mr. Sparkle
Sep 11, 2015 02:57 PM
Sep 2, 2015 07:33 PM
