Steeda Adjustable Panhard Rod...clunks?
Has anyone else who has the Steeda adjustable Panhard Rod noticed that it clunks when going over bumps and taking sharp turns? I got underneath the car and confirmed that it's the threaded rod end inside the tubular portion thats clunking. Anyone know how to fix this? The jam nuts are fully tightened already.
Fully tightened to the point where I can't move the wrench anymore. I can try raising the car up for some more leverage, but I can't really see this requiring any more torque.
I've found quite the opposite. Stock except for GMS LCAs clunked like mad at low speeds. The "train track" test made me wince. After the shocks, panhard, and sways, the car is much tighter. The TT test is not a worry. Looking at the torque specs, I would suggest using a lift or jack stands. These take some *** to get tight. Sorry, thats an aircraft maintenance industry term.....
I was planning on getting the Steeda adjustable Panhard Rod. What are you doing to confirm the clunking? Here's what I found on the bar...
"the Panhard bar is poorly designed. I can not tighten one of the ajusting nuts. Because the sits to far into the bracket that mounts on the body's end. The ajustment should have been somewhere of center of the bar so you can get to it."
"if you take it off, loosen both sides an tiurn it the whole bar should shift to one side giving you the clearence. I have the same bar on my 06 and I had no problems adjusting it."
The question is, are the jam nuts loose or is the bar defective?
The question is, are the jam nuts loose or is the bar defective?Here's a picture of what that bracket looks like and the clearance involved.
Attachment 30170
You can get at it, but just barely with an open ended wrench (1 1/8th) and with the help of some long-nose vice grips, you can actually loosen and tighten it. Then you would loosen the nut on the other side of the bar and just turn the bar (car still on the ground, bar still installed) and it shifts over the whole *** end of the car. Then just re-tighten and you should be good to go. Of course as you can see above, it's that one side that has the problem.
On another note, I saw this photo op when I had the car up in the air...
Attachment 30173
And while I was taking pictures I thought I'd get a shot of another Steeda issue I have. If you look at these pictures (one on the left is with the car in the air and the suspension unloaded, the one on the right is with the car on the ground), you'll see that with no weight on the suspension, the antiroll bar actually contacts the bracket to the right. When the car is on the ground, there is plenty of clearance. Has anyone else had a similar circumstance with their Steeda 7/8" Street Swaybar?
Attachment 30171 Attachment 30172
Dude ... the rear sway bar is installed upside down.
[/QUOTE]
Attachment 30173
Attachment 30171 Attachment 30172[/QUOTE]
[/QUOTE]
Attachment 30173
From your photos posted, I can see the panhard bar has a wrenching flat on the driver side. Get a wrench on the jam nut on the passenger side, get another wrench on the bar wrenching flat on the other end and torque the heck out of it. Does Steeda have a spec? if you don't get these tight enough the threads will start to fret and will eventually pull out or the rod end thread will break ... take your choice.
Note: Locktight will not make up for an undertorqued bolt!!!!
If you are happy with the length, and you can't tighten it fully otherwise, take the bar off and do the thightening on the work bench, keeting in mind to keep the ends aligned.
[quote=RadBOSS;968030]Dude ... the rear sway bar is installed upside down.
Actually...yeah. I feel like a total dumba$$. My friend and I couldn't figure out why we were getting such crappy clearance with the suspension unloaded when we installed it. We tried everything but flipping the bar the other way around. About 20 min under the car and it's fixed now!
You can see there's much more clearance now
Attachment 30205
I just wish we had figured it out before this happened:
Attachment 30206
Now there's plenty even with the suspension hanging.
Yeah that's a typo. I originally had the size listed for the 18's I was planning on getting till my cash went into the suspension
Oh yeah the pic on the left at the bottom is after I fixed the sway bar. The one on the right is beforehand, and you can tell it don't look right...
Attachment 30205
Attachment 30206
