Squeeking noise help
There's a light squeaking noise while I'm driving. Stops when I'm rolling really slow or stopped. Thinking its the TOB. Not effected by the clutch or AC. Ideas?
Does it make noise more or less depending on if you are accelerating or coasting? It could be a whine from the differential if it's related to the car moving. You recently put in 4.10's right? How many miles have you put on them?
Originally Posted by Agent MOO
If it's a throwout bearing it should be louder when you press in the clutch.
Does it still squeak when you coast in neutral? Have you tried revving the engine to see if that has any effect on it (in neutral or clutch disengaged)? Just trying to rule out an exhaust leak because I just found out that a broken seam on my cat was to blame
Rando
8/25/21 11:12 AM
