Spring install - How hard is it?
Old Oct 4, 2006 | 08:10 AM
sts767's Avatar
I got the Eibach pro kit and am trying to decide if I should install it myself or not. The shop that painted my stripes will do it for $200 and I am comfortable with their quality of work. I would like to do it myself but worry it might be a little complicated. I assume I can rent a spring compressor from Autozone. Are there any other special tools required? Any tricks to this install? How hard of a job is this?
Old Oct 4, 2006 | 09:45 AM
Boltzman's Avatar
Taco Bill did an excellent wriite up of his Ultrlite install. The rears are easy..its the front thats a little complicated. My mechanic also said he would not install my fronts unless I bought a camber kit..If it was me,I would pay someone 200.00 in a heart beat.Just not worth the aggravation IMO..Plus you know its done correctly and can take it back if there are any probs.
Old Oct 4, 2006 | 10:23 AM
Here's the link.
With the Eibach Pro kit, you will need a set of adjustable camber bolts.
If your install price includes an alignment, it sounds like a pretty good deal.
If you decide to do it yourself, expect to spend at least 5 hours (being that it's your first time).
Old Oct 4, 2006 | 10:24 AM
-FROG-'s Avatar
Took about 3 hours to put my Sportline kit on.
Old Oct 4, 2006 | 10:30 AM
emperorjordan's Avatar
its hella easy. the only thing I would do.... dont rent a spring compressor. just take the whole strut assembly to a suspension shop, and have them swap the actual springs for you. They did that for me for $30 after I spent hours trying to make a spring compressor that didnt fit work, then getting it stuck on there. lol.
Old Oct 4, 2006 | 10:34 AM
Boltzman's Avatar
I knew Taco would chime in here
Old Oct 4, 2006 | 11:17 AM
Mellow Yellow's Avatar
I did a spring swap with no previous experience and honestly, it really wasn't *hard*. Time consuming, yes, because I had never done it before, but it is pretty straight forward. I used Tacobills write up(thanks bill!) as a guide and it went well. Backs are easy, fronts are a bit tougher. If you can find a shop near you that will compress the spring and swap it out, thats the way to go. I had to do it myself because the shops around here wanted 1 hour labor for a 10 min job so I said screw it and rented a spring compressor.
All in all I am glad I did it myself
Old Oct 4, 2006 | 11:26 AM
mastersmech1's Avatar
All true as long as you are comfortable with your mechanical ability.
Old Oct 4, 2006 | 12:03 PM
neil07gt's Avatar
Just curious, since these are the same springs used on the GT-H, does the GT-H have the camber bolts? I wonder how the GT-H fixes the camber issue that would exist by having the FRPP handling pack.
Old Oct 4, 2006 | 01:25 PM
Ford probably uses their own fix.
File Type: pdf
Old Oct 4, 2006 | 02:34 PM
sts767's Avatar
I am curious as to a definative answer on whether you need camber bolts or not. I have seen numerous people who say you dont and numerous who say you do. What gives? Any insight into this particular topic would be appreciated.
Old Oct 4, 2006 | 02:35 PM
Cali HP addict's Avatar
The price your shop quoted sounds OK. If you are really into your car and have any mechanical abilities you should do it yourself. That way you get to "know" your car much better which is half of the fun. Renting a spring compressor is cheap and works well. There was someone on another forum who, before raising the front of his car, removed the retainer nut on the top of the strut, then jacked up the car. This allowed the spring to de-compress fully and safely while still in the car. You usually can re-install lowered springs without a compressor because they are short enough that you can start the retainer nut.
Jim74656
May 1, 2023 02:15 AM
SMBJoshy
Aug 24, 2015 10:55 AM
RocStar69
Aug 21, 2015 07:33 AM
