Some new Mods
Those magnapaks sound awesome! Any drone?
A couple of tips on the Pro 5.0 shifter;
1. Put some lithium grease on the brass bushings.
2. Be sure that you have the bushings on the proper side
3. Attach the shifter handle to the arm on the passenger side.
very little drone, i'll try the grease on the bushings, I put the big bushing on the driver's side per instructions
With the shifter handle set on the highest position and the handle mounted on the passenger side it will give you more leverage and help the 5th - reverse issue untill you get afew 100 hundred shifts on it. Then adjust the height that you like best.
Been there, done that!
