So, I must have a bad fuel injector or two...
I can't seem to run the Bama 93, or even 91 Race and TQ tunes without severly retarding the timing. I get pinging at the HP peak (5500) at WOT in 4th (heavy load). They're fine up to 4k or so. The 91 Race tune I had to retard above 4k 4º, and increase richness 4%, but I could still feel the engine dropping the timing back further (I could feel a little loss in power under WOT).
For clarification purposes, I only (have ever only) bought Shell V-Premium 93 octane fuel.
Even the 87Perf, I got some slight pinging at 5500, so I retarded timing 1º above 4000, and advanced timing 2º below 4000 to get some of the torque back, then increased WOT A/F richnes 2%. That combo seems to work: feels peppy and torquey below 4000, but no pining at 5500.
I read the maintenance schedule manual for the car, and not once does it mention flushing the injectors. I'm wondering if I should have the local shop do that for me and see if there's a difference, although I should probably run some fuel injector cleaner through first.
I'd love to run the 91TQ tune again...the TQ tune's my favorite.
Any suggestions?
Any suggestions?
Most times pinging is not caused by the gas unless you are using too low octane for the spark advance. Shell V-Power has extra detergents in it - I doubt that you have dirty injectors. I also have the 87-91-93 tunes on my XCal from Brenspeed and I find that heat is the main cause for pinging for me. I drove about 30 miles to the local dragstrip, then within 5 minutes I was in the staging lanes and running down the track. I ran a 14.4 and pinged so bad I had to let off. I only used 93 octane Shell while I was running my 93 tune. Then, I let the car cool down for 30 minutes and reflashed to the 91 tune (which I assume has less spark advance at WOT). I ran a 13.7 and had no pinging after that. I think running a cooler thermostat (180 vs 192) will help as well as using one heat range colder spark plugs.
Try different gas; try a different tune. Contact your tuner or try a different tuner's tune and see what their thoughts are. Pull a spark plug and inspect it. Replace your fuel filter.
Try any of these, or do all one at a time......... I would doubt you have a bad or even more doubtable a couple of bad injectors.
Thanks, I just emailed Brent..and I included that you referred me to them. Maybe a different tune will do it...I also like the idea of a lower temp thermostat, and of the cooler plugs. I need guidance on both of these parts: who are the better suppliers? what spec do I ask for?
Thanks again!
Thanks again!
I guess that would be optimal, a dyno tune...I probably need to wait until I get the headers installed so as not to have to do it again...so who in Houston is a reputable dyno-tuner?
Thanks again!
Thanks again!
That's a good idea, of course. I question, however, how a tuner can tell if there's detonation occuring during a run, what with all the noise from the FRPP Stingers (and they usually have the windows down)?
If you are interested, Doug will be in OKC on Jan.23 and willbe doing dyno tuning. I am sure between his tune and if something minor needs repairing then this could be a perfect chance to get it fixed. I work for a dealership here so if anything is acutally wrong we can get it fixed easily.
Blake
Blake
Blake
Blake
Thanks for your comments and input...that sounds like a great opportunity., if I don't get it done by a local tuner first, and if I'm in the country (I travel for work outside the US a lot).
My car's still under the the 60k60mo powertrain warranty (under the 36/36 bumper to bumper, in fact) and I also have the Premium-Care 6yr/100k extended warranty from Ford....my local dealership is "understanding"...
Brgds,
Marc
Any suggestions?
Any suggestions?
If its a tuning issue, he will make adjustments as required and email the new tune to you, takes all of 5 minutes.
This is a value added service that he provides to his customers.
Good Luck
Its really a coin flip some times it works sometimes is does not. Id bet more often than not the canned tunes are more than a bit off.
The easiest solution is to give Doug a call and ask him which points to datalog, then email the datalog to Doug followed up with a call. He will tell you exactly whats going on and how it can be corrected.
Good Luck
Good Luck
Thanks!
IMHO, first make sure all of the CAI connections are tight.
If they're ok, then run the Shell gas out of the tank, and try a different brand as suggested by tom281.
If changing gas brands does not solve it, and if there was no pinging problem when previously using those 91 and 93 octane tunes with the same ambient temperatures, then dump a can of Seafoam into the gas tank, and see if the pinging goes away after 200 miles or so. This cured a WOT pinging problem on my S197 when it had only 17K miles on it.
Hey Marc,
There is a good tuner right around the corner from you in Webster that I use. He has an 05 himself and his own shop.
I will PM you the info. He does great work! Got my car into the 12's with what's in my sig.
I'm hoping to get my car dyno tuned at Sutton in Illinois. Although that's far off in the future, a dyno tune is always best.
I'm sure Brent's tunes are great, but I still think that a dyno tune will always be better.
Thanks, if the combo of switching gs and Seafoam, and Brenspeed's tunes don't work, I'll do the dynotune...if I can only get hold of Patrick at PSI!!
Rando
8/25/21 11:12 AM
tacbear
9/27/15 12:57 PM
