Shocks needed?
Old Sep 29, 2005 | 05:37 PM
SurfnSoCal's Avatar
My buddy was telling me that if you lower your car more than an inch, you have to replace the shocks? is this true? He is a big BMW guys....so maybe its different..? confused.
Old Sep 29, 2005 | 05:48 PM
yikesaz's Avatar
No, you don't HAVE to change your shocks. I'm running Pro-Kit springs with stock shocks. I'd like to do better (it's a little harsh) but I'm used to it now & I'm happy.
Old Sep 29, 2005 | 05:50 PM
ex-Galaxie500's Avatar
It's probably just a good idea to change the shocks to improve ride quality, but I doubt it is absolutely necessary
Old Sep 29, 2005 | 05:52 PM
SurfnSoCal's Avatar
eh, he is saying that stock shocks aren't made to ride at that height, so therefore they will wear quicker.
do we have struts in the back?
Old Sep 29, 2005 | 06:50 PM
adrenalin's Avatar
shocks are definately required when raising a vehicle. In regards to lowering a vehicle, most people don't feel the need to change them. Which is why most shock manufacturers offer several different packages (such as Eibach). If you do go with the system that has the proper shocks you will get a smoother ride and better handling. Again, this is not necessary, just an option.
And no, we do not have struts in the back. Springs and shocks in the rear, struts in the front.
Old Oct 4, 2005 | 03:52 PM
RadBOSS's Avatar
Well generally speaking, when you lower the car you need stiffer spring rate because the suspension now has less travel available to control the bump. Like wise, the shocks need to be valved differently to maintain control (dampen) of the stiffer springs (whether you cut coils or installed a kit). You can get away with stock shocks on a lowered can, but you are also giving away some ride and control.
jim010
31
Sep 14, 2015 08:39 PM
Last1
Sep 5, 2015 01:23 PM
GLOCKer
Aug 13, 2015 09:55 AM
09-gt/cs
05-09 Exterior Modifications
Aug 2, 2015 10:08 AM
