saleen sc question
JDM sells the motor mounts that will drop the motor the 1/2" that it needs to have not rubbing issues at all, the Saleen will fit but like the engine cover it will rub a bit on the hood liner
You are right that would be crazy to remove the engine to change the mounts. You can use an engine hoist and a sling to suspend the engine while you swap out the mounts. Don't be lazy and try and jack the engine up from the bottom either. You could damage it doing it that way. I didn't have to worry about the hood though since I bought the Saleen hood. It is a vented hood and reduces the heat in the engine compartment.
I just thought that it would make it much easier, I had no idea how to do it as I have never changed the mounts before. Good news I guess as I have been thinking of it as of late.
1 Post
Actually you can jack the motor up safely! Steeda and BBK both recommend doing this when you install their headers! I had to raise the motor about 2" to install my Steeda shortie headers! and from the looks of it thats all you would need to install the motor mounts!........
1 Post
Actually! you place the block of wood in the front of oil pan where it mounts to the motor! not directly on the pan! on the oil pan flange! in between the harmonic balancer ( Crank Pully ) and front of oil pan! I repeat not directly on the oil pan! The 4.6 3V motor only weighs about 420 lb's using a piece of 4x4 6'' inches long gives you about 24" inches of jacking surface! and your only raising the front of the motor so your actually lifting 250 lb's thats only about 10 lb's of force per square inch! I did it! It's a piece of cake! just take your time! after I was done believe me I checked everything over close! This process didn't even smudge the paint on the oil pan flange! this far simpler and easy than it sounds!
Well I guess that I am fortunate to always have the right tools for the right job available to me. Using a jack and a block of wood to support my engine instead of an engine hoist and sling which are designed to do the job just seams like the caveman way of doing it to me. But if you can do it without damaging anything more power to you. Just don't ding your balancer if the jack slips.
1 Post
