Rearend not centered??
Old Oct 21, 2011 | 12:25 AM
mrpittbull08's Avatar
I put a set of 10" bullets on my GT with 274/40 tires. This made me realize that the rearend is WAY out of center. I have a set of GroundForce lowering springs Im fixing to install. Now..can i move it over any without having to buy a adj. panhard bar? Or do i need to get one first and put it all in together...Thanks
Old Oct 21, 2011 | 12:48 AM
Victorfriessen's Avatar
I dont know about the panhard but mines off center too and after I noticed mine Ive seen it on many vehicles now
Old Oct 21, 2011 | 05:30 AM
blackgt87's Avatar
You need to buy an adjustable panhard bar to center it.
Steeda sells a nice one that's double adjustable (you can adjust it on the car) for a decent price. I think it's chromoly too.
Old Oct 21, 2011 | 08:31 AM
2011GB/CS's Avatar
Yup, i need to buy one also. I lowered mine an inch in the front and 1.5 in the rear and it kicked the rear-end out. I'll probably get the Steeda.
Old Oct 25, 2011 | 04:51 AM
Cavero's Avatar
You might also want to look at some other manufacturers. I've had the Steeda unit on my car for 4 years or so, and it's a great piece, but adjustments are a P.I.T.A. because they put the locknuts at the ends of the bar. So on the passenger side the chassis bracket it installs into gets in the way. I ground down a cheap Am-pro wrench to clear it so I could tighten it down, but it's still not all that easy. BMR makes one that has the adjustment mechanism in the center of the bar.
Old Oct 25, 2011 | 05:54 AM
Doogie's Avatar
Definitely look into an "on-car" adjustable version like BMR or UMI as they are definitely easier to adjust.
Old Oct 25, 2011 | 07:14 AM
ricksGT/CS's Avatar
Talking
Here's pictures ,,,they work good ,, Rearend not centered??-551454-r1-02-23a.jpg
Old Oct 25, 2011 | 07:22 AM
VTXFrank's Avatar
I have the Steeda one also and it IS a PITA to adjust if you don't grind a wrench down for it.
But yeah OP, an adjustable PHB is the only way for you to center the axle. The stock LCA's aren't adjustable at all and neither is the factory PHB. PHB bars are pretty cheap though. Personally, I would recommend that if you plan on doing LCA's, relocation brackets and lowering, that you do it all at once if possible. Otherwise, you'll be adjusting the PHB after each install.
Old Oct 25, 2011 | 01:37 PM
MTAS's Avatar
BMR FTW as far as ease of adjust-ability on the car! http://www.bmrsuspension.com/?page=p...&productid=172
Old Oct 25, 2011 | 05:34 PM
Cavero's Avatar
Yeah here's what you have to deal with on the Steeda (those 3 are all steeda bars):
And the problem spot:
Old Oct 27, 2011 | 10:55 PM
blackgt87's Avatar
How often do you really adjust it? I centered my rear end once and thats that...
Old Oct 28, 2011 | 06:45 AM
Doogie's Avatar
Unless you change your springs again, it should only need to be set once.
Old Oct 28, 2011 | 06:53 AM
blackgt87's Avatar
Exactly. So it's not like you'll always be under there messing with it.
JTB
Motorsports
Sep 23, 2015 06:39 AM
