Rear Trailing arms Torque box reinforcment
Old Jan 5, 2006 | 06:22 PM
davids2toys's Avatar
Upon removal of the rear trailng arms, cant help but notice the apparent weakness and slightly elongated hole I have in the front mounts.I understand that different companys make these beef up reinforcements for pre 05 Stangs, is there any for the 05.....ANY INFO?
Old Jan 5, 2006 | 06:53 PM
Cleveland's Avatar
Nothing available yet from what I have seen. Subframe connectors add support to the box though.
-Dan
Old Jan 5, 2006 | 10:12 PM
2005MineralGT's Avatar
I haven't seen anything, but as Dan said, some of the subframe connectors reinforce that area. Also, I saw an article in one of the magazines where they welded some hardened washers to the control arm mounts for reinforcement to keep the holes from elongating. Adding the washers required longer bolts also.
Old Jan 5, 2006 | 10:44 PM
Cleveland's Avatar
I believe that article was based on what went into Justin Burcham's 9-10 second car. Welding in chromoly washers would be all many of us really need. BMR Subframe connectors dont really need to be added until you want to up the boost or the shot. Basically, I suppose it could be a rule that as long as the stock rotating assembly remains subframes arent going to be needed.
-Dan
Old Jan 6, 2006 | 04:47 PM
Yes, I did see that article about the washers welded in...The reason I started this thread is because I am having problems with my Steeda street/race LCA's
Fords4Ever
Oct 30, 2015 09:07 PM
Sep 8, 2015 10:45 AM
