Rear Diff Oil - Which Brand Better?
Old Apr 29, 2008 | 06:33 AM
SeanD's Avatar
I am purchasing all the stuff to complete the rar end change to 4.10, and the last thing to get is the oil. I have been checking around for the different 75W140 Synthetic gear oils, and where I am the choices are very limited. I'm in Canada, and good ole Canadian Tire only stocks I think a Valvoline (sp?) synth gear oil in 75W140.
Since I am close to the USA border, I went over to Michigan to see what I can find, and at Autozone they have Mobil-1 synthetic 75W140.
Is Mobil-1 good for the gear oil? If so, do I still need to add the friction modifier to it, as I have seen that it has it in it already.
I have tried to source out Royal Purple, but I don't want to look at getting it shipped, as the costs would be too much.
Old Apr 29, 2008 | 08:51 AM
I used Mobil-1 synthetic 75W140 (it's expensive!).
And yes to adding Ford friction modifier.
Old Apr 29, 2008 | 09:19 AM
metroplex's Avatar
Redline synthetic. It's less expensive than Mobil 1 or Motorcraft and works very well for Ford applications.
Old Apr 29, 2008 | 09:47 AM
SeanD's Avatar
Thanks Bill.
I know it's expensive. In Michigan it's $15.99 a bottle. I guess I will just pick them up the next time I am over there this week.
Now just have to get the gears installed!
Old Apr 29, 2008 | 10:25 AM
dustindu4's Avatar
9 is not my lucky number.
I would consider mobil-1 and royal purple to be equivalent to each other
Old Apr 29, 2008 | 10:57 AM
metroplex's Avatar
Just don't use Mobil 1 75W-90, it has been known to be ****-thin and allows for premature axle bearing failure. I've never heard of this problem with competing 75W-90 synthetics, so I am avoiding all Mobil 1 gear oils.
It's interesting how Mobil 1 and Motorcraft synthetic gear oils can cost nearly $20 per quart, while other true synthetics such as Red Line, Amsoil, and Royal Purple are under $10/quart and have generally seen limited distribution.
Old Apr 29, 2008 | 11:40 AM
RKNMACH's Avatar
I used RP 75W140 whichc already has friction modifier added.
Old May 1, 2008 | 12:05 PM
07Foose's Avatar
Amsoil
Old May 5, 2008 | 01:25 PM
PenguinGT's Avatar
For rear gear oil, I've always been happy with Royal Purple, Amsoil, and Redline.
Old May 5, 2008 | 01:28 PM
2006stang's Avatar
I have used Redline with excellent results. Any synthetic will be fine.
Old May 5, 2008 | 03:12 PM
07alloygt's Avatar
Yeah, most people seem to think that.
I haven't personally used any Redline products, but I know a lot of people who sware by them.
I think if you go with anything like Mobil 1, Royal Purple, or Redline (all with friction modifier), you'll be set.
Old May 5, 2008 | 04:19 PM
travelers's Avatar
+1 thats what I used also
Fords4Ever
Oct 30, 2015 09:07 PM
dblhelx
Oct 6, 2015 08:08 PM
seaclam
Sep 25, 2015 01:29 PM
