Rear badge construction
This piece in fact does have two alignment holes and uses clips to hold the badge on the deck lid. The GT emblem is encased in plastic that has a metal backing that appears to be tack welded to the badge itself then ground down to a flush backing. A piece of rubberized sticky Pad/tape sits between the badge and the deck lid. I tried to remove the GT emblem in favor of an original style snake as seen on the 65/66 GT 350 but was unable to do so without damaging the badge.
The badge can be reinstalled, it just slips into place and the original clips go back on,didn't mean to mislead anyone. Just letting you know that if you attempt to change the inner plastic GT emblem that you will probably end up destroying the badge.
That's definately good info dhof303
But I need to know were the indent's are for the front fender GT emblems are? I want to remove those emblems and put my snakes in thier place. I think I found a solution for the rear emblem. Thanks for the info though it helped!
I too am interested what lies beneath the GT emblems on the front fenders. I haven't attempted to remove them but I might ask the body shop if they think that they can get them off without much trouble. My next day off is Thursday so I can get back to you about them then.
Snake badges = more power. lol I can never understand why some people try to make the car something it isn't. Let those why buy a Cobra wear their's and let the GT stay. No offense Vegasjay.
) She will be a version of the Shelby. It's all good....
Here ya go guys, the answer to your burning questions about where the holes are. Kevin (05Stangkc) helped me out a while back by sending me a tracing of the "GT" badge with the alignment pins marked on them so I could go ahead and put my running pony's on without worrying they'd fit.
Print the attached pic and it'll come out actual size, you'll be able to see that the holes are fairly close, aligned north/south.
Have fun, Mark
Have fun, Mark
MTAS is right. Heat makes it simple, then hit it with "Goo Gone".
I shave the trunk, and there are two holes on a horizontal plane, about an inch apart. Those can be covered by one emblem. That is, or a pony (You don't have to go back to the round fake fuel door.
Same construction on the fenders, but you would need a pony or something that will cover the odd location of the holes.
Rando
Aug 25, 2021 11:12 AM
Sep 10, 2015 12:44 PM
