Ram air thing
Originally Posted by AlsCobra
They do make them. They also make replacement element tubes. But in all honesty, a larger MAF housing is not necessary in 05+ mustangs. The housing is really not restrictive and there's no point in going bigger housing unless throttle body is much bigger that the inlet tube and MAF. CAI and inlet tube with stock MAF is fine for most applications.
I do believe that CAI is worth it but not one with a MAF housing. Fresh cool air will help the vehicle operate more efficiently. Maybe not much hp increase or even fuel mileage increase but it will be more efficient.
Originally Posted by texastboneking
The factory air box gets the air from the same place a cai does. How could a cai get colder air than the factory air box then they are both drawing from the same place?
My filter is way down in my fender well and it will draw in colder air. And the cone shaped filter will be less restrictive than the factory set up. Is it a big advantage over stock? Probably not but every little bit helps. And it sure looks a lot better also. Quit being cheap and quit trying to argue.
And if you wanted to be"cheap", all you need is a drop in filter and you get a better flow
Well you know, Ford's just lying. They don't know anything. What's Randle know anyways?
“Colder air reduces intake losses,” said Randle. “The new cold-air intake has shown a reduction in rise over ambient temperature from 50 degrees down to 17 degrees Fahrenheit. That equates to more horsepower and more torque in all driving conditions.”
thanks to the airflow increase that the new system promotes.
"Colder air reduces intake losses," said Randle. "The new cold-air intake has shown a reduction in rise over ambient temperature from 50 degrees down to 17 degrees Fahrenheit. That equates to more horsepower and more torque in all driving conditions."
What bothers me about cai is most ppl believe they are Gods gift to their cars, they thint they just gained 50hp! And its common on this forum too.. there are guys here who believe the cold air intake makes the car.
Does the intake help? In most cases yes. Its a minimal gain. But I'm not gonna **** my pants in amazement with this "awesome power for the money" bull****..
Originally Posted by Zaksgt
<img src="https://themustangsource.com/attachment.php?attachmentid=99734"/>
This is my 04 GTO, you should be me right now because were still waiting on a transmission lol. It's a fun build me and my dad are doing.
"The new setup, formally referred to as the '05-'08 Mustang GT 85mm cold-air kit with premium CAL (PN M-9603-GTB; $669), is basically the same air-intake system that highlights the '08 Bullitt Mustang's engine bay. "
So what was the size of the stock 08? See what I'm trying to learn from you?
Yeah I know they arnt necessary. But ppl that don't know anything think "bigger maf = more air flow". That's why I think cai are not near what they are hyped to be. The car can only suck in so much air. The factory intake system isn't that restrictive. So changing it to a bigger intake doesn't really improve the flow all that much like ppl think it does.
Some CAI's, like the Bullitt one that Charlie keeps pointing to, DO draw the air from a different and possibly cooler location.
Back to the original RAM air thing -- I like the basic idea of getting high pressure cool air direct to the airbox, if done right it seems like it could almost be like a "free" supercharger . . . not a big boost like a real supercharger, but it seems to me if done right you should be able to get a psi or two out of it when the car is moving fast
The FRPP/Bullitt CAI is designed to suck in cooler outside at all times, even when the car is idling at a standstill. (I believe the same is true for the WMS CAI).
This design feature is obviously important when either waiting at a stoplight, or waiting in line at the dragstrip.
I was once tempted to swap out my current CAI for an FRPP unit, until I figured out a method to completely isolate the heat shield from the hotter underhood air. Before-and-after IAT data logging indicates it works as intended.
I can also feel a small SOTP performance increase with the isolated heat shield after the car has been idling at a standstill for a minute or so with the engine fully warmed up in hot (80 F +/-) ambient temps. This SOTP performance increase was confirmed when I beat another 05 manual S197 GT(also with a CAI/93 tune) by half a car in a 40-100 mph rolling race(both started in 2nd) immediately after we were sitting at a stoplight for at least a minute with fully warmed up engines in 85 F ambient temps. And yeah, he knew how to shift.
Originally Posted by ski
Gotta respectfully disagree. Not all CAI's are created equal.
I finish it Saturday morning when my final par gets here
