Ram air thing
I found this for Bullitt
Bullitt CAIs include a new 85mm mass air meter. Our GT's stock sensor is retained.
Fuel requirements are important elements of CAI upgrades. With the Bullitt kit in place, Mustangs that ran on lower-octane gas (87 or 89) before the upgrade are now married to a 91-octane minimum thanks to the airflow increase that the new system promotes.
Originally Posted by cdynaco
No - Ford tuned it, but that's beside the point. Let me rephrase, what is the 08 stock GT's maf? Aren't you on your computer at the shop?
Also found this
And since you haven't tuned vehicles you wouldn't know what is actually changed in the parameters when you tune on. Not trying to be rude.
I ask this because I own Ford's 08 Mustang manual and have been frustrated because they don't show Bullitt specifics. They don't even show the FRPP CAI. So I have been seeking specific information. If you don't have knowledge about it then say so.
estimates:
CAI = 15HP
Tune (nonFRPP) = 10-25HP
Cams = 30HP
Ported Heads = 20HP?
Longtubes/Xpipe = 30HP?
Intake/throttle body/injectors = 30HP?
All of the above in combination =
A proper CAI with tune for A/F is less money and less involved than any other thing on the list.
"The new setup, formally referred to as the '05-'08 Mustang GT 85mm cold-air kit with premium CAL (PN M-9603-GTB; $669), is basically the same air-intake system that highlights the '08 Bullitt Mustang's engine bay. "
So what was the size of the stock 08? See what I'm trying to learn from you?
Don't pull rank on me son. That shows poorly on you. I don't give a fk what you've tuned or haven't.
And I said I don't know bullit part numbers or specifics. I just know why the tune is required. The tune does also change some other parameters but it is required for the maf.
No comment?
Its possible the maf is the same size but has a different resistance value to read more air than a factory maf can read.
I'm not necessarily trying to pull rank. But I'm telling you what I know and I know why a cai. Requires a tune. And its for a different resistance rating in the maf.
And does your manual at the shop (I assume you're on computer for details, schematics, etc.) have specifics for Bullitt separate from GT?
Fair enough. So the Bullitt 85mm is how much larger than stock?
Originally Posted by Zaksgt
Lol I don't believe any of that! Did they know you were racing, and I don't think you raced a Buick GNX maybe a grand national!
Go back to the old fox operating systems. Larger MAF allowed more air in which leaned out the air/fuel ratio coupled with larger injectors and fuel pump.= the ECM doesnt know that more air or more fuel is entering the engine and it operates just like it did without the upgraded parts. With one or the other,MAF or fuel upgrade, the O2's would just show bad mix and fight to compensate.
Alright, obd2 system is a bit more responsive and complicated. MAF tube upgrade, fuel upgrades, need to be tuned for. Timing and air/fuel respond way too quickly to just "trick" it. ECM will go into a preset fuel map "safe mode" before it will allow it to damage the converters. The ECM's main job is to protect the cats and a lean or rich condition will damage them.
Larger MAF housing without a tune will require a different designed element that will give the ECM a signal that more air is going into the engine which is more complicated than just a reflash to compensate. One thing the obd2 system will not allow is a rich or lean mixture because of possible converter damage. Unless the tune is bypassing some values.
Originally Posted by texastboneking
This is true. But a larger inside diameter in a maf will slow the overall flow through it causing the maf to read low air flow and run lean.
It's actually gonna read lean before it shows low air flow. 02's will pick it up first.
And the o2s will only pick it up once the o2s get warm enough and it goes into closed loop.
So at first the engine will try to run on a preset set of parameters and the maf will make it fail to idle. Or at least in most cases that I have seen it couldn't idle.
Either that or a recalibrated MAF sensor itself. Recalibrated sensors have been used before and work the same way with no tune required. Only problem with that is it wont work if throttle body, intake, or fuel upgrades are done also.
I haven't seen a recalibrated sensor for obd2 vehicles. As far as I know they just recalibrate the tune instead of the sensors.
As far as I know that's only on old fox bodied cars.
