Quick C&L Racer intake install question?
Old Jul 15, 2008 | 12:31 PM
coair73x's Avatar
I got the intake and shortly will install. I noticed this MAF housing does not have a bracket or the need to remove the one bolt in the valve cover for the bracket install. I wonder if this is correct? This is a lighter design then the Street intake so mabye no bracket is needed. Has anyone else recall having the bracket on the Racer intake? Going to put my Steeda LCA`s following Tacobills install intructions first. Thanks BILL! Then on to the Intake then TUNE!!! I will be out in the Garage with the laptop. Thanks for any input!!
btw I did call C&L and left a message with the question. And got some new bolts for the MAF housing. This intake did not come with the bolts just FYI......
Old Jul 15, 2008 | 03:46 PM
SoundGuyDave's Avatar
Nope, no bracket on the valve cover at all. The heat shield bolts down on the fenderwell and zip-ties to the brake lines at the ABS box.
Old Jul 15, 2008 | 08:45 PM
coair73x's Avatar
thanks for the reply... that is how I installed it... It fit like a glove and will be easier to remove when I go to the Dealer for what ever......
Old Jul 16, 2008 | 10:50 AM
mot250's Avatar
Correct, the lighter weight of the plastic Racer inlet tube does not require the bracket attached to the valve cover like the aluminum inlet tube.
How do you like it? I've had mine since Sept 06 and have not had it off except when necessary to remove it temporarily to add other mods
Old Jul 16, 2008 | 03:12 PM
coair73x's Avatar
I love the intake... I will only take it off when it goes to the Dealer so I don`t have any issues. I have the full warranty package.
Old Jul 17, 2008 | 06:53 AM
travelers's Avatar
No bracket required.
Old Jul 17, 2008 | 08:09 AM
Originally Posted by coair73x
Thanks BILL!
ur welcome! Hope the installs went well.
Old Jul 17, 2008 | 05:38 PM
coair73x's Avatar
yes bill it did... dunno if I would have been able to takle or do it correctly with out all those pictures. I hope to have a better 60`ft with them. Did you notice some noise from the axle area after your install? It is not that loud but sound like a slight whine when decelerating thru various speeds.
Old Jul 21, 2008 | 07:44 AM
No, quiet during accel/decel. I have the FRPP 4.10 'A' gears, if that makes any difference.
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
ssjbuu
Aug 28, 2015 08:55 AM
Ecoboost
Jul 25, 2015 06:32 PM
