question: overdrive on the highway...
Old 2/24/06 | 02:17 PM
Machine's Avatar
not sure of the answer, so please have some patience... [img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]
lets say I'm doing about 50 or 60mph on the highway and O/D is on.
I decide to turn O/D off (the infamous pinky click) and gun it to pass some slowbie.
I kick it to about 5500 rpm to pass and turn o/d back on...
is it bad for my 5r55s in the long term to do this?
Old 2/24/06 | 02:36 PM
lodom's Avatar
Does the 5r55s not shift down a gear by itself fast enough to pass, or do you feel you get better response from taking it out of overdrive? Either way it should drop down to 3rd to pass, so I can't see how taking taking if from 5th to 4th by the button, and then giving it gas to downshift to 3rd to pass would help. Unless you just enjoy pressing the button.
Old 2/24/06 | 02:44 PM
Machine's Avatar
I forgot to mention that I am running 3.90 gears...maybe that plays a part.
to answer your question - yes, it feels more responsive pressing the button. I dont know if it is fact or not, but it certainly feels like it pulls harder from about 3.8k than it does at 2.8k
Old 8/7/07 | 10:03 AM
NJJOE's Avatar
I tried turning the OD off and it definately is more responsive when making a pass on the highway. Is it bad to turn OD off and on? Never got an answer. How about others out there. Have you tired this and how do you use the OD?
Old 8/7/07 | 10:18 AM
RobK's Avatar
Not bad. You're simply forcing a downshift. Of course, once you roll into the throttle it'll likely downshift to 3rd anyway. Technically you shouldn't need to do it at all. It'll take care of the downshifting for you.
Old 8/7/07 | 10:21 AM
06GT4RAD's Avatar
This is fine. You are doing nothing that will harm the transmission. I do this all the time and have done so for years in my F-150. Doing it manually like this is much faster than waiting for the car to respond on it's own based on pushing the gas pedal.
Richard
Old 8/7/07 | 11:07 AM
Burke0011's Avatar
Big Falken Tires
used to do that all the tim in my old 05 auto - go to town man!
Old 8/7/07 | 05:09 PM
NJJOE's Avatar
Thanks guys! You are right the response time is MUCH quicker and sometimes that can save you. LOL....Appreciate the help!
Old 8/8/07 | 01:09 PM
just pull the lever down into 3rd or 4th depending on your speed and punch it... the heck with that button
Old 8/8/07 | 01:48 PM
awakeinAZ's Avatar
I think it's easier to pop the OD button and add a little gas to compensate for the RPM change. Easier on it then floor it and wait for it to downshift. If you pull it down to 4th it will down shift two gears.
Old 8/8/07 | 03:34 PM
06GT4RAD's Avatar
Do not do it this way if you do that it will go from 5th gear to 3rd gear not the best idea when driving at freeway speeds.
Richard
Old 8/9/07 | 02:29 AM
nynvolt's Avatar
I click off the OD button below 60 on the freeway all the time. If I jab the gas to speed around someone it will often jump down two gears, into third and sound like I'm trying to be a jerk or showing off. It shouldn't be a problem, but I'm in no way a mechanic. The trans is designed to be shifted manually if you desire, although the set up isn't very good for this, other wise if you put in in 3, it would cycle from 1st to third rather than just lock into 3rd. This is what I base my opinion on, that it shouldn't damage the trans at all.
Old 8/9/07 | 07:37 AM
Richard
I did say depending on your speed.
Old 8/9/07 | 09:53 AM
06GT4RAD's Avatar
Yes I know but you have to always assume that people do not understand that or take what you say literally and might try that at 90MPH Always assume you are dealing with someone who may not have a clue.
Example 1: http://www.mustangforums.com/m_36388..._1/key_/tm.htm
Example 2: http://www.awdpirates.net/phpBB2/vie...er=asc&start=0
Richard
Old 8/9/07 | 10:53 AM
ren274u's Avatar
these cars wont downshift unless its a safe speed. I messed around with a rental one day, even though i had the shifter in 2 around 60 it wouldn't shift until around 45
Old 8/9/07 | 11:53 AM
They're designed not to let you do something stupid. If you have a manual, you shouldnt be able to shift into like 1st at 100, you know? Using the OD button should be fine, we used it all the time when vacationing in the mountains. Where exactly is it in the car, pics? I dont want a auto, but I'd like to see it anyway.
Old 8/9/07 | 01:29 PM
cmplxlgc's Avatar
there ya go
Old 8/9/07 | 02:21 PM
That doesnt seem like an easy button to push, lol.
Old 8/9/07 | 03:07 PM
don_w's Avatar
As long as you have a right pinky finger, it's a piece of cake.
Old 8/9/07 | 05:45 PM
Richard
point taken and I stand by my first post LOL
