Prothane motor mounts
Location: New Carlisle, Ohio (20 miles north of Dayton)
Hey Guys,
Since I am getting ready to install longtubes in the next few weeks I am considering changing the motor mounts to the Prothane brand. They seem to come in red and black urethane. Red is a little softer durometer than black. ( I think) I just want some feedback from guys running them whether or not the NHV is that much worst with them. They do not cost that much but I don't want a bunch of unnecessary vibration if I install them when doing the headers. You guys that have them...please post your opinions of them.
Thanks Scott
Thanks Scott
Scott
I think I have read they will lower the engine about 1/2 inch. If I don't like it I will just make a spacer for them. I don't know what's wrong with me. I am in a big time modding mod!!!!!!
Scott
1 Post
That's a good price. A little better than I just bought them at. I have read that will lower the engine height about a 1/2 inch and that will be better for the header clearance ...I think. If I don't like where they sit I will make a spacer for them. I am just curious about increasing NHV!
Scott
Scott
Earth to Scotty...Come in Scotty.
I just ordered the headers about 1 hour ago so I can't answer that question. However... on Larry's car (Aircare84) I would guess it had about 1/8 to 3/16 inch clearance. I know that seems close but the engine rotates away for the steering shaft under hard acceleration.
Scott
1 Post
Scott
Scott
The prothane mounts do increase nvh a little, but not to the point of being uncomfortable. I got jdm lowering mounts, but i'm not sure if they are any different from the reg prothane mounts. They did drop my motor about 1/2", but that is why i bought them........needed the clearance for the s/c.............I have jba lt's and did have to trim a bolt on the pass side because the header was hitting it. I would suggest doing the mounts prior to doing the long tubes.........i had to cut the stock mount to get it out (because i didn't feel like pulling off the pass side header)......
I can't say for sure because I don't have them installed yet. As for a I know Larry ( Aircare84) has not complained about a steering shaft rub. Maybe you need to let go of about $130 bucks to fix your issues.
Scott
I am hesitant on ordering them because dropping the engine will therefore drop my shaker scoop and if you drop the scoop by 1/2 an inch, it will look pretty gay IMO. Hey Scott, hurry up and put yours on and let me know how it looks.
Well...since I can't see how your Steeda headers fit up next to your steering shaft I guess I can't say for sure if the motor mounts would fix your issue. However.. on Larry's OBX longtubes dropping the engine 1/2 inch would have increased the clearance he had. Maybe you just need to change your header brand. I really don't know for sure.
Scott
Scott
1 Post
Well...since I can't see how your BBK headers fit up next to your steering shaft I guess I can't say for sure if the motor mounts would fix your issue. However.. on Larry's OBX longtubes dropping the engine 1/2 inch would have increased the clearance he had. Maybe you just need to change your header brand. I really don't know for sure.
Scott
Scott
I edited my post about your brand of header. I would suggest you talk to Steeda about your issue. I have not seen it with the OBX longtube brand on Larry's car. If I have an issue with it on my car I will post an honest opinion of the problem. That you can be sure of.
Scott
There is no difference in the red and black Prothane mounts. I have the black and they actually raised the engine about a 1/4 inch. If you want to go lower for a Saleen supercharger or some other reason buy the shaved mounts from JDM engineering!
There is more NVH especially on startup but personally I like it and the motor seems tighter. They work great with the CHE torque limiters and brace.
I hope this helps you out Scott.
