Pre-cam's dyno (Will update after install)
Old Jan 11, 2009 | 06:15 PM
06GTwJUICE's Avatar
I made a trip to RET yesterday and talked to them about the tuneing and nitrous.
I ended up dropping it on the dyno for pre-cam numbers.
271whp 298tq
Their guess after the cam and delete plate install was around 300-305ish whp.
Install will commence once the spring tool arrives.
Old Jan 11, 2009 | 06:19 PM
officespace56's Avatar
What kind of cams are you dropping in?
Old Jan 11, 2009 | 08:15 PM
06GTwJUICE's Avatar
Competition Cams VSR Stage 2
Old Jan 11, 2009 | 08:21 PM
302svt's Avatar
Subscribing
Old Jan 11, 2009 | 10:10 PM
06GTwJUICE's Avatar
Created a post for headers to go with my setup.
Old Jan 12, 2009 | 11:12 AM
gmantheman's Avatar
Does RET use a Mustang Dyno? If so, your numbers look about right. If he is using a dyno jet, your numbers look a little low. With your mods now your SAE corrected numbers should be about 290 RWHP/305 RWTQ
Old Jan 12, 2009 | 11:31 AM
06GTwJUICE's Avatar
It was a Dynojet dyno.
SAE corrected?
Old Jan 12, 2009 | 04:07 PM
gmantheman's Avatar
Not sure what SAE stands for,but it's supposed to give a more accurate reading than STD numbers. I believe STD conditions are set for a temp of around 60 deg F, which were as SAE numbers are set for a temp of 76-78. SAE numbers will be about 4-5% lower than STD numbers. Dynojets will use either STD or SAE corrected. It may say on your dynosheet.
Old Jan 12, 2009 | 05:10 PM
06GTwJUICE's Avatar
It was 72 degrees at the time of the dyno.
The printout is kinda cut off on the bottom of the page but I can make out that part.
Old Jan 13, 2009 | 10:38 AM
Rebel73's Avatar
SAE = Society of Automotive Engineers
How's about that? Sumthin' from auto shop stuck!
Sep 10, 2015 12:44 PM
Sep 10, 2015 08:31 AM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
JTB
Motorsports
Sep 3, 2015 10:50 AM
