power/speed/granny shifting
Old May 7, 2006 | 07:50 PM
nonsensez9's Avatar
can someone explain each of those terms? thanks
Old May 8, 2006 | 06:28 AM
Zodiac's Avatar
Power shifting generally applies to the idea of shifting without ever letting up on the gas, hard and fast.
Granny shifting generally applies the idea of shifting lower in the power band, generally slowly and carefully.
Not sure on speed shifting exactly.
Old Jun 1, 2006 | 07:22 AM
stkdidy's Avatar
speed shifting would be what 90% of people do...shifting aggressively, but letting off the gas momentarily during shifts
Old Jun 3, 2006 | 07:24 AM
fin1's Avatar
Power shifting and speed shifting have different meaning to different people. Some consider them the same, which is shifting w/o lifting your foot off the gas. I've seen definitions of speed shifting that state it is shfiting w/o using the clutch or using just enough clutch to shift. Then others calls this clutchless shifting.
Granny shifting is what most do on the street: shift w/ the clutch and let off the gas between shifts.
Old Jun 4, 2006 | 11:59 AM
INTRUDER's Avatar
While wqe are at it.......
What is double clutching ?
Old Jun 4, 2006 | 02:04 PM
karman's Avatar
Old,Old school.
Before trannmissions had gear synchros, the only way to get the gears smoothly running at the right speeds and to engage properly was to push in the clutch, put the car in neutral,let out the clutch, push in the clutch, then shift into gear.
Thus the term "double clutching".
If this sounds outrageous, when my dad was a kid ALMOST ALL cars did this.
This is when the definition of speed shifting involved little or no clutch (and a lot of gear grinding noises).
Old Jun 12, 2006 | 07:53 AM
stkdidy's Avatar
Originally Posted by karman
Old,Old school.
i was pretty much sure that it referred to pushin in the clutch, putting it in neutral, rev-matching for the next gear, then putting it in and letting out the clutch...on MODERN CARS, that is. with no real need to literally "double clutch", the matching of rpms replaced the second use of the clutch.
jim010
Jun 24, 2024 04:23 PM
Gigantor
May 11, 2023 07:31 PM
K.A.I.N
Sep 25, 2015 03:27 PM
