PJ302 Cam Questions
![Question](https://themustangsource.com/forums/images/icons/icon5.gif)
I have a Parnelli Jones ed. Saleen ordered and am considering a few subtle performance mods, one being a cam swap. The PJ uses Saleen-spec camshafts made by Comp Cams. A recent 5.0 Mustang magazine article places the specs in the 230 degree/.440 lift range due to emissions restrictions. What effect might a swap to something along the lines of Comp Cams XE261H-116.5 which is .490/.480 lift and 222/235 duration?
My thoughts are that as much as cams do for the stock 4.6, they should shine even more on a stroker with higher compression. The larger displacement combined with the higher compression is also the reason I would consider the largest of the Comp line.
LT's and o/r X- or H-pipe as well as a larger tb would also be used to take advantage of the extra camming...
![Popcorn2](https://themustangsource.com/forums/images/smilies/popcorn2.gif)
Barrett you should have heard my Comp Stage 4's yestarday after Doug tuned the car.....SAWEET!!!!!!
I am surprised that with all the knowledge on this board no one has chimed in with anything on this subject.
