Painted Mac mufflers black
Its Rust-Oleum High Heat. resists heat up to 1200 degrees.
http://www.rustoleum.com/CBGProduct.asp?pid=112
this one will give you more of a glossy look instead of the flat black look
http://www.rustoleum.com/CBGProduct.asp?pid=108
That paint will probably last 1 year tops and start peeling off. It won't protect metal from rusting. I've been there and done that.
The only way to stop the mufflers from rusting out (internally and externally) is by using stainless steel (T-409 or T-304 is most common for exhaust). I'm sticking with my stock manual GT mufflers.
Again, I've been there and done that with the "high heat" paint. That rubbish will start peeling off soon or it won't protect the aluminized junk from rusting. I've had much better luck with regular Rustoleum paint, the one that ISN'T rated for high heat, but sticks to hot exhaust parts much better (go figure).
eh the engine paint that i used on my brake calipers held up and is still holding up after 5 years and a couple of times at a road course (this was on my old V6 and my cousin owns it so i still see it now and then)
