Our 8.8 rear end uses the 28 spline axles, right?
If Ford is using the same 31 spline 8.8 LS carrier it used in the Broncos and F-150s then I'm sc+&#^d. I grenaded both my '88 Bronco LS rear end and my '96 Centurion LS rear end in the same manor. Here are some photos of the '96. The white chalk marks the thickness of the tapered end opposite the ring gear. There is not much steel there and the problem is compounded by the sharp 90 degree cuts for the dog eared clutches. Those sharp cuts are an excellent place for cracks to start and when the rear end goes it opens up like a clam shell at that end.
Pardon the rust as these parts sat out in the weather for a couple of months before I got a digital camera.
BB
BB
The Factory LS unit is actually a pretty weak unit overall. The case is very thin. I myself plan on going with the Eaton LS. You can also by the upgraded spring kit and bump them to 800Lb. I run one in my F150 4x4 and it has held up like a champ even with running the larger tires.
Richard
Richard
The 8.8" carriers have worked fine for the past 20+ years unless you really abuse them.
I've heard lots of good things about the Toyoda/Zexel/Gleason (whoever owns the patent now) Torsen differential (the original). I got burned badly by TracTech (or whoever owns TrueTrac) with my grenaded 8.8" trueTrac and won't ever buy another TrueTrac.
Or, I could just re-install the stock DS, which is a noodle/damper, and which masks the rear end problem, and do w/o the Spydershaft.
With having to deal with Ford's Trac Lok 8.8 in my 4x4s for over 20 years I personally think it's a piece of junk. I don't abuse my vehicles, I'm well within the stated towing capacity when pulling my boats. All of my 4 wheeling consists of sand trails or algae covered boat ramps at low tide. No mudding and no rock climbing. I've grenaded two Trac Locs in the exact same manor. I am not alone with this assessment, several others on my Bronco forums have experienced similar problems.
I don't have any problems with the 8.8 open diff carrier, it's what Ford did to that carrier to accept the passenger side clutch plates that frustrate me. Having the same carrier in my Mustang bothers me, especially considering that I'm leaning towards FI on this car.
BB
BB
BB
BB
I've heard nothing but great things about the Tru Trac. IMO, Don_w has who knows how many runs on his and he's putting out quite a bit of power with his Kenne Bell. Plus it's a dd as well!
The carrier for the Trac Lok is Junk as Centurion said. I also have eaten a few of the 8.8's in my F150's. One of the reasons why Ford stepped up to the 9.75" Rear Ends with the 5.4L Engine the 8.8 cannot handle the added loads And it is most likely the cause of the vibration issue. And as they say" One Man's trash is another man's treasure"
Richard
Richard
Richard
Richard
Our 2003 E-250 has a Dana-60 (9.75") rear-end, but it also weighs 5500 lb and is a 8800 GVW vehicle with Load Range E tires and wheels (8 lugnuts), comparable to those used on the HMMWV.
The S197 GT w/ manual is 3450 lb and doesn't tow anything, nor should it be off-roaded in stock configuration. The wheels are rather flimsy compared to Load Range E wheels, and the tires certainly cannot handle the same load.
Essentially a 5.4L 2V/3V/4V truck with a Dana-60 is apples to oranges compared to any Mustang.
Now, if you had drag slicks or drag radials on a 400+ hp Stang and did 7k RPM clutch dumps (significant driveline shock), you're likely to grenade weaker differentials. The PowerTraxx units are known to grenade one after another in such an application but work just fine on off-roading trucks/4x4s.
I hear what you are saying though - the stock 31 spline units will sacrifice some material to fit in those splines. However, the 05-up Police Interceptors all have 31 spline 8.8" carriers and axles and haven't grenaded any Traction-Lok carriers. I'm sure you can find someone who has even grenaded an open 8.8" carrier. The stock LSD carriers are not bulletproof but offer a lot of bang for the buck.
After taking the Spyder to a driveline specialist, and having the balance checked (it's good), I rotated the Spyder 180º and the murmur is greatly reduced and threshold is raised...so I'm happy w/it...I was gonna do the 4.10's next week (my wife's bday present), but decided not too...it would raise the DS speed at the same vehicle speed, and I don't want to mess with what is an ok situation.
I'm gonna wait until the warranty wears out of the TracLoc grenades to make the change to a Torsen T-2, and for the 4.10's. The stealership Serviuce Manager said he's work with me on the rear end vibes even with the aftermarket DS...especially now that I can prove it's balanced (I got documentation from the driveline shop).
BTW, he used the Spicer J3253 critical speed claculator to calc the critical speed for the Spyder: 5800 DS RPM (132 mph with 3.55's, 114 mph with 4.10's)
They are holding up fine with modded GT500's right now, So its currently #459 on my things I worry about on my car list driving a CAI GT. Its right between peanut butter in the cd player and scratches on the jack handle on the list.
EDIT: label flaking off the baggie with the wheel lock key just bumped it one more down.
I am not saying that the 8.8" overall is weak. I am strictly referring to the LS unit. And you all can sit here and argue about it all you want it isn't going to change my opinion of them. The 9.75" Is way to large to stick under the Mustang so I do not see that Ford has much of a choice other than the 8.8" They at least beefed it up to a 31 Spline Axles which i think will help greatly but that may have weakened the LS Carrier even more.
I am not bashing the 8.8 it hasn't been around as long as it has by being and inferior axle but what they do to the LS housing to get it to fit the clutches is not a good thing and it makes the wals very thin. Unless they have changed that method.
Richard
Richard
#40
So...if the walls of the unit are thin, what does that mean? How does that make it weak? I'm not arguing, I'm just failing to see how that matters. Granted I'm no expert on gears. I know engines, not gears.
