Our 8.8 rear end uses the 28 spline axles, right?
Old Sep 4, 2007 | 03:12 PM
MrClean's Avatar
Question Our 8.8 rear end uses the 28 spline axles, right?
Looking at Detroit Truetrac LSD's.....
Old Sep 4, 2007 | 03:17 PM
05BlackGT's Avatar
They're 31.
Old Sep 4, 2007 | 03:23 PM
MrClean's Avatar
Thanks!
Old Sep 4, 2007 | 03:27 PM
bazguitarman's Avatar
Stock is 28 spline. An upgrade would be to 31 spline. I`m pretty sure of that. You should also check out the Auburn Ected differential. Acts as a true LSD until you lock it up. Then it`s locked tight. I`ve done some research and can`t find any instances of failure so far. And the price is very reasonable. Around $600.00 I think. 31 spline axles shouldn`t cost you more than $350.00 to $400.00 for a street/strip type replacement.
Eric
P.S.- And definitaly ditch the stock two-piece drive shaft. A good one-piece alum. unit shouldn`t cost more than $600.00
Old Sep 4, 2007 | 03:32 PM
MrClean's Avatar
Thanks, I got the Spydershaft...
Old Sep 4, 2007 | 03:39 PM
Spydershaft FTW.
Eric
Old Sep 4, 2007 | 03:41 PM
kevinb120's Avatar
31 Spline stock, 28's were on the SN95's and earlier Fox bodies.
Old Sep 4, 2007 | 03:42 PM
tom281's Avatar
We have 31 splines stock..... the 28 was in previous gen cars.
Old Sep 4, 2007 | 03:43 PM
metroplex's Avatar
Our stock differentials also have the same carbon-fiber clutch discs as the ones used in the 03-04 Cobra and the 07 GT500.
Old Sep 4, 2007 | 06:58 PM
MrClean's Avatar
31 Spline, got it! If the Spydershaft turns out to be balanced (I got a "murmur" at 100+ mph - on closed roads, naturally ), then I'm replacing the stock LSD with a Detroit Truetrac when I do my 4.10's....
Old Sep 4, 2007 | 07:10 PM
tom281's Avatar
Wow Marc that would be a nice setup. You won't regret the 4.10s either!
Old Sep 4, 2007 | 07:14 PM
MrClean's Avatar
Thanks, I just need to work on the wife, and explain why the stocker needs to be replaced...
Old Sep 4, 2007 | 07:25 PM
metroplex's Avatar
The stock 2-piece shafts are rated for 145 mph at the factory with the 3.55s, so I'd say they are pretty good.
Old Sep 4, 2007 | 07:41 PM
Wow, seriously the stock axles are 31 spline? Awesome.
Cool, that takes some $$$`s off my mod list. Learn something new every day.
Eric
Old Sep 4, 2007 | 08:22 PM
LAK3RS's Avatar
I wish I would have just replaced everything in the rear end when I had my gears done! Do it right the first time around!
Old Sep 4, 2007 | 08:44 PM
That`s a good way to save money on labor. I may try to do that myself. I`m seriously looking at the Auburn Ected differential. Hopefully there will be more user reviews out before I do that. It seems like a really neat unit. Regular clutched LSD when unactivated and totally locked with the flip of a switch. I don`t see how it could get any better. I wonder how it would stand up to power on the street.
Eric
Old Sep 4, 2007 | 10:40 PM
MrClean's Avatar
I want the Torsen or Truetrac because both don't use clutch packs, they use parallel helical gears...hence nothing to wear out and need replacing...and the diff fluid doesn't require a friction modifier.
Old Sep 5, 2007 | 12:07 AM
kevinb120's Avatar
You should do other stuff untill you really need it For now its like going out of your way to find $400 lug nuts. I guess if you're doing gears though, but sounds pricey for little difference in a n/a car.
Old Sep 5, 2007 | 02:56 AM
metroplex's Avatar
I grenaded my 8.8/28-spline 2pinion trueTrac. I think they're poorly designed copies of the Zexel/Gleason/Toyoda Torsen differential. I know how they work and why they're supposed to be better. However, the torque biasing from a Torsen is inferior to that of a viscous coupling limited slip, especially one with the carbon fiber clutches.
Old Sep 5, 2007 | 05:33 AM
tom281's Avatar
Well, I used the old "honey, you remember how I said the rear tires are always wearing out faster than the fronts for some reason? Well, these new parts back there may help that........"
