Oil Drain Plug Torque
Old Nov 26, 2005 | 08:01 PM
thestoogeo's Avatar
Does anyone know how tight the oil drain plug should be when reinstalled? In ft/lbs or Nm.
Jon
Old Nov 26, 2005 | 08:04 PM
korinwoodo's Avatar
Just a question also. How do you measure how much torque you are putting on the bolt?
Old Nov 26, 2005 | 08:53 PM
f1-cobra's Avatar
26 Nm (19 lb-ft).
Colin, you will need a torque wrench.
Old Nov 26, 2005 | 09:05 PM
thestoogeo's Avatar
Thanks for the info.
Jon
godspeed's Avatar
1/4 turn past tight works for me
Old Nov 26, 2005 | 09:21 PM
slammer223's Avatar
Tighten it till it starts to strip, then back it off a half turn.
Old Nov 26, 2005 | 09:27 PM
Cleveland's Avatar
I havent used a torque wrench for any of my auto projects for a few years now. After a while of constant wrenching it becomes pretty easy to estimate the correct needed torque. In other words, Im the torque wrench.
For the oil drain plug, you really shouldnt have to apply much force to tighten it, a socket wrench with a bit past "hand tight" is good.
-Dan
Old Nov 27, 2005 | 09:45 AM
Import-Slaya's Avatar
Or install one of these and never worry about it again:
http://forums.bradbarnett.net/index.php?showtopic=39655
Old Oct 26, 2011 | 01:12 PM
kylerohde's Avatar
Originally Posted by f1-cobra
26 Nm (19 lb-ft).
Bringing a 6 year old thread back from the dead, but does anybody know if this is really correct? Seems really low to me.
Old Oct 27, 2011 | 06:55 PM
825LTRGT's Avatar
The shop manual says 19 ft/lb.
Mine doesn't leak and is not stripped either.
Old Oct 28, 2011 | 06:00 AM
-Dan
no way! What about your lug nuts? You can tell they are all at 100 ft pounds with out a tq wrench?
Old Oct 28, 2011 | 10:24 AM
I've never used a torque wrench for the oil drain or the wheels. And I change wheels (studs) twice a year. You either have the feel or you don't.
Old Oct 28, 2011 | 10:52 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
There's a torque spec for that?!? Lol. I never torque down oil plugs or lugnuts.. what do you thinks gonna happen if ones at 75 ft pounds and ones at 150 ft pounds??? The wheels gonna fall off????
Old Oct 28, 2011 | 11:30 AM
warp a rotor?? play hell getting the 150 off on the side of the road when you get a flat?? Kinda worries me to have a ford tech talk like that
Old Oct 28, 2011 | 11:56 AM
Bear Eats King...
Bear ****s Bone
Lol warp a rotor? How? It's still tight. Just not super tight.
Old Oct 28, 2011 | 12:03 PM
fdjizm's Avatar
I always torque to spec, the spec for the oil drain plugs is "tight but not too tight".
Old Oct 28, 2011 | 12:06 PM
Bear Eats King...
Bear ****s Bone
Exactly
Old Oct 29, 2011 | 09:01 AM
have to say I have never used a tq wrench on the drain plug but on lug nuts I use one almost every time.
Old Oct 29, 2011 | 09:12 AM
Bear Eats King...
Bear ****s Bone
The specific impact gun I bought maxs our at 120 ft pounds. So I know if I don't just hammer it till it completely stops turning that i am pretty close to the 90-100 ft pound mark. I can say that 20 lbs difference will not warp a rotor.
Old Oct 29, 2011 | 09:49 AM
That's why I hate 'air impact torque'.
If I tighten them myself, I can loosen them myself.
