ODBII port relocation?
9 is not my lucky number.
Has anyone seen a kit that lets you relocate your OBDII port? It's such a pain in the hiney to datalog because it's right in front of the clutch. The tuners only use like 5-7 pins. I'm thinking of going to a junk yard and getting a used port and mounting it under the passenger side and running wires to tap into the back side of the existing one. That way nothing is in the way when I'm racing.
Do what I did and just remove the 2 retention screws and secure the OBDII port somewhere under the dash with a zip cable or something. I leave my Predator plugged in all the time and I didnt want the plug to be in the way anymore.
-Dan
-Dan
Well, do you just want to use the Diablo to datalog or do you want to stream to a laptop? I select RPM, Speed, Intake Air Temp, Coolant Temp and Timing Advance as my Drivibility options and use those as my regular guages. I hardly ever read the from the cluster anymore.
-Dan
-Dan
Big-D
7/27/15 11:24 AM
