Octane question
Former Vendor
This is exactly correct. The spark table is set up for 87/89 from the factory. The difference with just 1 degree of timing on the three valves can be amazing. On F/I motors 1 degree of timing can be as high as 20HP in some areas.
CR
CR
The Ford Press Release on the Bullitt says:
Engine performance is further enhanced through the use of an innovative adaptive spark ignition system, new for the 2008 Mustang.
The system can sense, within a few seconds, what type of fuel is being injected into the motor and adjusts the spark to provide maximum torque at any given speed - and as much as
10 pounds-feet more between 1,000 and 4,000 rpm.
Bullitt can run on either premium or regular fuel. Ford recommends premium fuel for optimum performance, but the adaptive spark ignition will adjust the spark to burn regular fuel without damaging the engine.
I am curious as to whether this "adaptive spark ignition system" is included in all 2008's, is a job 2 add (with Bullitt building); or is unique to the Bullitt.
It seems that it may be in all 2008 GT's. Question really is -- if that is the case and you have the 90mm CAK -- which is what is in the Bullitt, will the timing on the Ford tune retard enough to burn 87 without detonation?
My wife drives an Acura TSX with a 91 octane recommendation. It will burn 87 -- the computer adjusts and just lowers the output.
If the 08s will do this -- it gives you the option of filling up with lower octane for regular driving and higher octane when you want the 325 ponies.
Anyone have any information on whether this system is in all 08's -- it may be why the tunes were later getting out -- and whether it works?
You might want to test your fuel economy as well. That extra timing that the computer can put in with higher octane fuel does help fuel economy. On some cars, the improvements in fuel economy can offset the slight cost increase in the fuel itself.
On my 05, I saw a 1/2 mpg increase overall (averaged over several tank fuels for both grades and in similar driving conditions, aka: my daily commute!). My sisters '96 T-bird (4.6L) is down right picky about fuel. It gets anywere from 2 to 3 mpg more on 91 (best available up here) vs 86. Its enough a difference for her that it actually costs her money to use the "cheap" gas.
You have to love adaptive, learning computers!
It seems that it may be in all 2008 GT's...Anyone have any information on whether this system is in all 08's -- it may be why the tunes were later getting out -- and whether it works?
I think this is a very good feature for the new Bullitt.
Thanks Mark. My Dealer is waiting for my tune from Ford Racing. He is also trying to find out whether this feature is active. It is a great feature period -- protects you against underperforming fuel and the works. I'm continuing to look for information. Only problem with the whole deal is that Ford Racing takes about a week to get the tune to you.
Almost all cars have knock sensors, including the 05-07's. The difference is just that the revised knock sensors for the Bullit (and possibly the 08GT's too) evidently have the ability to add more timing if it is determined the octane rating is high enough to support it...thereby increasing hp.
The old knock sensors just pulled timing, but would not add any extra timing if you were running say...91 octane. It would still protect your engine from lower than 87 octane fuel though.
The lowest grade gas here is 95RON (~93 octane US), so I could never compare it to 87, but once I filled up with 100RON gas in Germany and there was absolutely no difference in performance, since I didn't have a tune at the time.
Save yourself the money and don't use 93 unless you add a tune.
I use Meijer 87 octane in the Mustang and get 23-24 mpg on the highway.
Charlie:
Any knowledge on the 08 programming -- is the adaptive system advertised for the Bullitt -- 87 -93 w/ 325 horses on the high test (w/ Ford Racing CAK) going to be the same on the regular GT. I'm still waiting for the tune from Ford on mine -- and trying to figure out if I'm going to be able to get the Bullitt Flash.
Charlie:
