Nitrous tuning Info.....and nitrous tip's in gen.
#41
Originally posted by mikem@October 25, 2005, 3:59 PM
Are they adjustable ?And what settings do you run them if yes?
#42
Originally posted by jp's performance@October 25, 2005, 4:26 PM
the are 10 way adj i run mine at 4-5 it all depends how the track is hooking,now stop righting to me and call jegs and order your stuff,step it up.![Big Grin](https://themustangsource.com/forums/images/smilies/biggrin.gif)
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
#43
John I was looking at our interier setup.A cage is going to be tricky without hacking the inside up.
#44
Guest
Posts: n/a
Originally posted by mikem@October 25, 2005, 7:10 PM
Dont you worry
Plugs will be here tomorow.I overnighted the shocks from Summit and i will put the 100 octane in this time remove some timming and Hope it stays together with the 150....I hate being in third ![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
Dont you worry
#45
Originally posted by Blazing Saddles@October 25, 2005, 7:32 PM
Wait till Pete datalogs my fuel system Friday night. If the fuel system won't support the 150 shot, there go your plugs again, or even worse.
#46
:bang: I forgot to tell you guys.friday night i was pulling into my small garage and i happen to run over a push broom that slammed against my rear quarter.Nice good size dent right on the seem
#48
Guest
Posts: n/a
Originally posted by clockworks@October 27, 2005, 7:14 PM
Is it bad to have your bottle open (but not armed) all the time? If so, why?
#49
Originally posted by Blazing Saddles@October 27, 2005, 5:42 PM
If there is the slightest leak in the N02 solenoid it will fill the intake system with N20 gas over time. When you go to start the car the intake manifold will be blown up through your hood.
-Dan
