New Tunes
New Tunes
Went ahead and bought 3 custom tunes from Doug. I asked for 87perf, 93torq and 93perf, in that order. Doug emailed the 3 tune files, named 1,2,3.
My question is since the tune file names do not state what they are, is it safe to assume Doug emails the tunes in the same order you requested them?
Also, each of Doug's files are 1.98mb. I can only get 2 of the 3 files on my SCT due to there size. Is there any work around to this?
I have emailed Doug, but due to his high demand I thought I might get a quicker response from you guys
I heard on the newer cars, ford changed the computer which causes the tune files to be larger. From what I read, there is no fix for it with the XCAL2. Sucks. But others may chime in.
As for the tunes, logicially speaking I would assume that is the case (order they are in being 97, 93t and 93p). Though I would verify with him. You could just throw in some 93oct, and test all three tunes. The TQ tune really does react a lot different from the performance, so its easy to tell them apart.
Location: New Carlisle, Ohio (20 miles north of Dayton)
My bet is when you download them to the Xcal2 they will come up on the screen of your xcal2 as to what each one is. Not 1,2 &3. And as far as the file size issue I don't know what to tell you about that accept keep the one you won't run that much on your computer. You will find the one you like and will probably stick with it as most of us do.
Scott
Scott
