NEW Generation 2 Whipple 2008 Supercharger Re-Design Kit! MORE POWER!
ATTN: ALL 2005-2008 MUSTANG GT MANUAL AND AUTOMATIC OWNERS!
Whipple Industries has introduced their all new Generation 2 Rotor Design for their Twin-Screw Supercharger Systems! This redesign will take affect on both the NON-INTERCOOLED kits and the 10PSI INTERCOOLED HIGH OUTPUT KIT! This newly designed rotor allows for higher boost levels at lower RPM as well as lower intake temperatures! This means more power and reliability!!! The tighter clearances will allow the motor to create more boost while still spinning at a slower RPM than the previous W140ax blower AND cooler temps as well! The newer design increases air flow and lowers parasitic loss to ensure that Whipple now leads the industry in both power and efficiency! All 2005-2008 Supercharger kits will now be shipping with this Generation 2 rotor design! CALL US TO RESERVE YOUR SPOT!
The new design for 2008 Mustangs incorporates a new manifold setup as well as a new calibration so that it may retain CARB exempt and emissions legal certifications. Because of the new tooling, design, and increase in parts, the new kit will sell for between $100-200 dollars more than the previously designed Whipple kit for 2005-2007 vehicles ($5775.99 for Black HO kit). Whipple will be releasing the exact price increase in the next few weeks. We have over 13 people waiting in line for this kit. We are taking deposits if you'd like to ensure your spot. Avoid any additional waiting for the new designed kit and sign up today! Keep in mind that this preorder includes the Generation 2 kit for ALL 2005+ Mustang GT's including both INTERCOOLED HO and NON-INTERCOOLED.
NOTE: THE 2008 MUSTANG KIT IS THE ONLY KIT AFFECTED BY PRICE - ALL 2005-2007 GEN 2 ROTOR KITS WILL REMAIN PRICED THE SAME AS BEFORE!
Please note that these kits come directly from Whipple Industries. This means that you are also buying only the best in customer service and technical support. Their knowledge-base has helped countless times for our customers. They have went above and beyond and helped in leaps and bounds; giving diagrams and even over-nighting replacement parts that were not a manufacturers defect! The only way to buy a Whipple is from Whipple direct!
CALL US TODAY IF YOU HAVE ANY QUESTIONS OR CONCERNS REGARDING THIS PRE-ORDER AND/OR THE NEW ROTOR DESIGN!
ALSO AVAILABLE: SPECIAL (1) MONTH-ONLY DEALS FOR IN-HOUSE CUSTOM TUNING AND/OR INSTALLATION ON WHIPPLE SUPERCHARGERS WITH YOUR PURCHASE OF THE KIT! CALL FOR INFO!
CR
Tillman Speed
610-497-5776 (or 610-497-3736 if busy)
www.TillmanSpeed.com
CR
Tillman Speed
Strange...I was just on the Whipple site and there is no news of this at all. You would think they would have it there some where...
I will keep an eye on this...Looks interesting. I hope the issue with the bearing breaking is resolved. Many have some bearing breaking off on the tension belt or something etc...
Vegas, They aren't going to do a formal press release for a few weeks here. I will post it for sure when it becomes available.
CR
+1 Black satin, I have no tuner, would like gauges in A pillar installed (have housing and can get gauges), running NA at the moment
Can you PM me info on the 400 hp kit (polished) possibly with the addition of the intercooler -- don't want to go with the high boost for engine longevity -- but figure with the right tune, low boost + intercooler ought to be a good combination. Thanks.
FYI guys,
here is the first dyno results of the Gen 2 whipple kits. 10psi
498 RWHP!!!! on whipple tune!!
http://www.moddedmustangs.com/forums/2005/65353-whipple-owes-me-explanation-dyno-results.html#post1037623
Whipple's make CR happy.
