New clutch with stock flywheel?
Old Apr 26, 2008 | 08:05 PM
Interested in upgrading my clutch when my motor gets pulled, seems like the perfect time to do it.
Question.. can I keep my stock flywheel? I have 2400 miles on it.
Not sure about entertaining the thought of upgrading to an aluminum flywheel because of my 1-pc Coast DS and 4.10 gears.
Old Apr 26, 2008 | 08:08 PM
tom281's Avatar
You can reuse your stock flywheel, although you may have to have it resurfaced.
FYI I am sticking with a steel flywheel of some type whenever my stock clutch goes.
Old Apr 26, 2008 | 08:11 PM
2kanchoo's Avatar
I've decided that's the route I'm going as well. spec 3+ with steel flywheel (and the street manors upgrade cause I'm a pansy) OH sweetass 1/4 mile times you got btw! Saleen TS ftw.
Old Apr 26, 2008 | 08:13 PM
tom281's Avatar
Originally Posted by 2kanchoo
I've decided that's the route I'm going as well. spec 3+ with steel flywheel. OH sweetass 1/4 mile times you got btw! Saleen TS ftw.
Thanks.
Old Apr 26, 2008 | 09:05 PM
Is it like turning the rotor when installing new pads? I can't imagine too much wear on my flywheel given the miles. Guess my shop will make the call on the condition of the flywheel (if I pull the trigger on a new clutch ).
Old Apr 26, 2008 | 09:11 PM
RadBOSS's Avatar
It is generally best to have it resurfaced. Blanchard grinding is preferable to turning, 2400 miles is not much unless you have been doing a lot of burn outs and hard launches. Cheap insurance though, considering the effort if the new clutch chatters because of uneven surfaces. Not quire the same as disk brakes.
Old Apr 26, 2008 | 09:22 PM
Tispco's Avatar
IMO, I'd have the stock flywheel resurfaced if you decide to reuse it. It is cheap insurance. If you end up having issues because you did not, you have to do the clutch all over again. It happened to me on a '66 Mustang. I was cheap and didn't resurface the flywheel and ended up having to replace the clutch within a few thousand miles.
Old Apr 27, 2008 | 06:37 AM
2400 miles that clutch isn't even broke in yet. Why spend the extra cash? Was there a problem with it?
Old Apr 27, 2008 | 07:45 AM
Robbieg's Avatar
Bill, you should have it resurfaced, and I assume you meant 24000
Or have you replaced the fly wheel before and only have 2400 on the new one?
Old Apr 27, 2008 | 09:03 AM
JonCo's Avatar
I'm sure he means 2400. Its his weekend/show car. Not DD.
Old Apr 27, 2008 | 09:06 AM
Looking at the Centerforce DF because I'll be at around ~500 crank HP so the stock clutch may not be up to the task.
No, 2400mi total on the car. I know.. it doesn't get driven too much.
Thanks for everyone's advise, I'll ask my shop what it costs to get the flywheel resurfaced.
Old Apr 27, 2008 | 10:09 AM
anthony05gt's Avatar
Hey Bill, I'm about to pull out my Centerforce DF after about 5k miles on it. I'm at about 470 rwhp and even though the DF has been an awesome feeling clutch it's recently started to slip. In my experience with other cars too I'd say use the DF up to 400 rwhp. Anything over that I'd go with a DFX set up. Also consider the McLeod hydraulic slave/bearing upgrade too.
Old Apr 27, 2008 | 11:16 AM
turbo05gt's Avatar
Bill your new motor is comig with a Cobra crank right? You will need to get a new FW anyway, you have a 6 bolt crank now and the Cobra is an 8.
Old Apr 27, 2008 | 12:18 PM
Cobrakev's Avatar
I paid $ 20 to have a fly wheel resurfaced. Most good shops will do it when installing a new clutch.
Old Apr 27, 2008 | 01:12 PM
2kanchoo's Avatar
There was a thread around about centerforce vs spec etc. A LOT of guys were saying they have had a lot of major issues with the centerforce DF. I'd suggest going with a spec stage 3+, or mcloed clutch instead. http://s197forum.com/forum/showthread.php?t=4804
Old Apr 27, 2008 | 01:54 PM
Robbieg's Avatar
There were a lot of people having problems with the original centerforce clutches but they seem to have it fixed now on the redesign. There is some good info here on it:
http://forums.stangnet.com/showthread.php?t=655782
Old Apr 27, 2008 | 02:53 PM
07alloygt's Avatar
Most clutches break in within 500 miles...
I would just have the stock steel flywheel resurfaced...like Tispco said, it's just cheap insurance.
Old Apr 27, 2008 | 05:16 PM
agreed I kinda miswerded my post..... barely instead of even.
Sep 23, 2015 03:21 PM
JonathonK
Sep 19, 2015 03:19 AM
samjluck
Sep 17, 2015 10:24 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
