Need a PDF for changing motor mounts
I bought some motor mounts and would like some install instructions on changing them. Can anyone help me out
1 Post
I was up close and personal with the GT motor mounts When I installed my headers!.......Read the ''Saleen SC thread'' I explain the easy way to raise the motor off the mounts! I thought about changing the mounts while I had the motor jacked, but I read that you gain a lot of vibration from the high performance mounts! Why do you want to change the mounts!
I bought a set of the red bullet Prothane red bullet motor mounts here on the board. I know a couple of guys who are running them and they have no vibration or noise. It felt like the car shifted better and probably less engine flex under wot. Bottom line is that I liked them and "if" I ever go with long tubes I would probably put them in anyway.
I'll check out your post, thanks~
Did a search but didn't find it. Do you have a link?
Rich... I've got the PDFs for the LH and RH Engine mounts from the 2005-2006 Factory Service Manual. Send me a PM with your email address and I'll send em back.... if this is what you're looking for great... otherwise, just trash the bits and bytes. Doc
9/16/15 06:44 PM
